October 12, 2016 at 7:26 am #975582
http://www.tuinhuizenfabrikant.be/nl/nieuws
On this page, things don’t show how they should in IE11. Does anyone know how to solve this?
- In IE9 I have other problems: the slideshows that show on top of each page aren’t displayed there. + The slide show lite (custom) on the homepage doesn’t position the title and description in the right way.
thanks,
Michiel
Saguaros ModeratorSaguaros
October 13, 2016 at 4:56 am #975884Hi Michiel,
I updated this css rule:
article .pull-left img { vertical-align: middle; max-width: 100% !important; width: 100% !important; }
into the custom.css file on your site.
You can check it now.
October 13, 2016 at 6:17 am #975905Thanks!
Just one question: how did you modify css if you don’t have access to ftp?
Michiel
October 13, 2016 at 6:33 am #975910Joomla 3 provides ability for administrator to edit template files under template manager section.
AuthorPostsViewing 4 posts - 1 through 4 (of 4 total)This topic contains 3 replies, has 2 voices, and was last updated by Saguaros 8 years, 2 months ago.
