  • darkpain Friend
    #149524
    Hello, a have a website running Ja Larix template and it seems that i have some problems on IE. Allthough it seems to work “almost” fine on my computer, it appears to have problems on other computers i opened the website. At some PC’s the problem is only the product images, that do not open in lightbox . On others the problem is the lightbox plus the header that looks half it’s size. On firefox it works fine. Please help i don’t seem to find where the problem is. The website is: http://www.madbull.gr Thanks alot! 🙂
    PS: Another problem with IE is that the template adds a big blank above “search” module, almost at the size of the header! :laugh:
    Dear darkpain!
    Pls fix this problem as following:
    1) Open the file : templates/ja_Larix/index.php and try to find codes:
    <style type=”text/css”>
    .clearfix {display: inline-block;}
    </style>
    and replace:
    </style>
    2) Pls check the HTML Source code, i saw a wrong code:
    <!– BEGIN: JA SLIDER –>
    <div id=”ja-sliderwrap” class=”clearfix”>
    <img src=”/images/stories/madbull.swf” width=”NaN” height=”50″ />
    </div>
    <!– END: JA SLIDER –>
    You put a Wrong URL for the IMG Tag, pls try to re-update this
    GOod luck
This topic contains 2 replies, has 2 voices, and was last updated by  Saguaros 14 years, 9 months ago.
