June 17, 2010 at 11:40 am #151870
Hello
I’m having a compatibility problem with paying a template: JA_RASITE
When browsing in Firefox or Chrome it works perfectly, except when it connects to the site with Internet Explorer layout bug (the site is more focused, its menus drop down off the fields, no multiple images longer occur, the site is “large”,) …I’m on it for a week and I can not fix the problem … Can anyone help me?
site : http://www.drakonia.eu
Saguaros ModeratorSaguaros
June 21, 2010 at 4:24 am #347538Dear drakonia !
Pls view html source code of this site http://www.drakonia.eu/. i saw the dirty codes as following:
<head><script type=”text/javascript”>
var _gaq = _gaq || [];
_gaq.push([‘_setAccount’, ‘UA-16709320-1’]);
_gaq.push([‘_setDomainName’, ‘.drakonia.eu’]);
_gaq.push([‘_trackPageview’]);(function() {
var ga = document.createElement(‘script’); ga.type = ‘text/javascript’; ga.async = true;
ga.src = (‘https:’ == document.location.protocol ? ‘https://ssl’ : ‘http://www’) + ‘.google-analytics.com/ga.js’;
var s = document.getElementsByTagName(‘script’)[0]; s.parentNode.insertBefore(ga, s);
})();</script>
<meta name=”verify-v1″ content=”07fgNP/tuhpUZ9FVQ9vEHGra1WScUiK412P22/J3akk=” />
<META NAME=”description” CONTENT=”Drakonia – Celest’Lan Gold Edtion derni�re �tape des Masters du Jeu Vid�o”>
<META NAME=”keywords” CONTENT=”drakonia, celest, lan, jeu, jeux, counter, strike, cs, css, source, trackmania, masters, jeu vid�o, cod4, cod, forum, homologu�e, 800, series, lots”>
<meta name=”norton-safeweb-site-verification” content=”y7y3c9n02xp48ay2d1aexjnl6j4l8qy-mde9x87w-0g289e3c3wlmgsre06-0qa8q52j-7dzsmadefssp21ef90s0zniigenwacl2kc3e00dejohi5162t59zrz8bi5-” />
</head>
<body bgcolor=”#FFFFFF”></body></html>please remove them to resolve this issue
Good luck
June 23, 2010 at 8:07 am #347808Oh…
Okay i have remove this code and… now it’s okay 🙂Edit : logos on the right menu does not appear in Internet Explorer. There is only one other picture that appears does not seem to load …
July 2, 2010 at 4:03 pm #348836up !
logos on the right menu does not appear with Internet Explorer… Anyone have an idea ?
July 7, 2010 at 9:57 am #349220you try to clear cahe on IE, i looked everything is ok
July 7, 2010 at 10:00 am #349222i have clear the cache but… problem is always here …
I use IE7…
This topic contains 7 replies, has 2 voices, and was last updated by Saguaros 14 years, 3 months ago.
