  • mkisite Friend
    #200053
    Hello.
    If i create a JA product tab on position Home1 and featured product in Home2, it’s quite ok.
    But i want some text instead of the product tab. So i use the custom HTML module to create these text and it works. But the layout of the featured product in Home2 is suddenly not correct at all. :-[
    I couldn’t find the way to repair it.
    Does anyone have an idea?
    Here is the site: http://www.mkimage.com/remembooktest/
    Thanks.
    1. ZsdoXnZ
    2. XF8EIsE
    chavan Friend
    #543671
    Please post your admin details in PM
    Also you have used Jch Optimize to optimize the css. this is causing the issue. Let me double check on this. If things are right with your template. Then you need to contact JCH developer.
    Let me check and confirm first
    mkisite Friend
    #543678
    Oh yes… It’ possible… I already have problem with this in the past, but il did’nt think about it anymore.
    Thanks for your interest!
    I sent you the admin details.
    chavan Friend
    #543679
    Added this code to templates/ja_hawkstore/tpls/head.php
    $this->addStyleSheet(T3_TEMPLATE_URL.'/css/vmsite-ltr.css');
    check your site and confirm
    mkisite Friend
    #543683
    Wow!!! 😀
    I did what you suggest and… It’s perfect!
    Thank you very much for that!
This topic contains 5 replies, has 2 voices, and was last updated by  mkisite 10 years, 5 months ago.
