  • carlicthus Friend
    #161807
    Hi, i have problem with the layout of ja_t3_blank when i do a search on aceSearch module; the left column go under de main content and the right column go to the left.
    If anyone can help me to fix that, thanks.
    http://leidev.com/test/index.php?option=com_acesearch&view=search&query=joomla&limit=5&Itemid=1
    1. jat3
    khoand Friend
    #382890
    Do you show me your default layout (Extensions–>Template Manager–>ja_t3_blank–>layout–>default)?
    What position does search module use?
    carlicthus Friend
    #382906
    it is the default layout. the search module is on left position, the problem appears on results of the search.
    <?xml version=”1.0″ encoding=”utf-8″?>
    <layout name=”desktop”>
    <!–Extra css load for this layout–>
    <stylesheets>
    </stylesheets>
    <blocks name=”top” style=”xhtml”>
    <block name=”absolute” type=”modules” style=”raw”>absolute</block>
    <block name=”top-panel” type=”modules” style=”raw” main-inner=”1″>top-panel</block>
    <block name=”header” type=”header” main-inner=”1″></block>
    <block name=”mainnav” type=”mainnav” main-inner=”1″></block>
    <block name=”cpanel” type=”usertools/cpanel”></block>
    <block name=”topsl” type=”spotlight” main-inner=”1″>user1,user2,user3,user4,user5</block>
    </blocks>
    <blocks name=”middle” colwidth=”20″>
    <block name=”left1″>left</block>
    <block name=”right1″>right</block>
    </blocks>
    <blocks name=”bottom” style=”xhtml”>
    <block name=”botsl” type=”spotlight” main-inner=”1″>user6,user7,user8,user9,user10</block>
    <block name=”navhelper” type=”navhelper” main-inner=”1″></block>
    <block name=”footer” type=”footer”></block>
    </blocks>
    </layout>
    khoand Friend
    #382976
    You must to set search module’s position is content
    carlicthus Friend
    #382983
    i dont know what you mean, the aceSearch module into content?, it is on left position now.
    khoand Friend
    #383050
    I have install AceSearch into my Joomla 1.5 with JAT3. And I get same error. Because AceSearch causes it. To solve this:
    Add this code into end of <joomla url>componentscom_acesearchviewssearchtmpldefault.php file
    </div>
    carlicthus Friend
    #383057
    yeah. thats right, so many thanks mate…
This topic contains 7 replies, has 2 voices, and was last updated by  carlicthus 13 years, 9 months ago.
