  • hendon Friend
    #123638
    I’ve got two layout problems with the Justica template running on J 1.5.
    When weblinks are selected, I get a broad black line with the words “The database that Jommla Uses” extending right accross the page and off to the right of main page area. This line only appears when a category of links is selected, and sits just above the list of links.
    The second problem is the screen layout when someone edits an article. The edit screen extends over the left module (Marked “L” on the layout guide). Because the edit screen is transparent, the underlying content in the left module can be seen through the edit screen.
    Anyone know how to fix these two annoyances?
    Michael Casha Friend
    #232394
    Have you got a live url?
    hendon Friend
    #232431
    Yes, Its http://cpc.triselcommunications.com.
    Please ignore the footer errors – this was an accidental file deletion – it will be restored later.
    Hope you will see the problem. If you need to login to see the problem with the edit layout, just use username: admin and password: admin
    Thanks. Hope to here from you soon.
    hendon
    hendon Friend
    #232432
    <em>@hendon 31534 wrote:</em><blockquote>Yes, Its http://cpc.triselcommunications.com.
    hendon</blockquote>
    P.S. You may also notice something strange happening to the newsflash module!
This topic contains 4 replies, has 2 voices, and was last updated by  hendon 17 years, 2 months ago.
