  • ivan1012 Friend
    #172660
    I’m having three problems with layout on my site. (Attachments in mail, problem 1,2 and 3.)
    First one if I put my new page to be category blog as a menu item Type and choose any model to go to the module position right, it shows underneath all the articles and not at the right side next to the articles.
    Second one at jomsocial homepage, new photos module has too big height and shows a lot of blank space.
    Third one is moving tweet and google +1 button from from under the facebook like box. and putting it right from the facebook like box! 🙂
    Please help!
    1. problem3
    2. problem2
    3. problem1
    matt871401 Friend
    #433346
    What JomSocial version are you on?
    jooservices Friend
    #433347
    Please provide your site URL so i can help you check it.
    Thank you
    ivan1012 Friend
    #433377
    I uploaded the necessary info…
    jooservices Friend
    #433379
    For this issue:
    http://www.joomlart.com/forums/attachment.php?attachmentid=18502&d=1326242180
    You will need update a bit into html . Please update FTP than i can help do that.
    http://www.joomlart.com/forums/attachment.php?attachmentid=18503&d=1326242234
    As far i remember. This’s JomSocial template issue because structure of html depend on sidebar. Please try to contact JomSocial about this issue.
    http://www.joomlart.com/forums/attachment.php?attachmentid=18504&d=1326242246
    May i know URL of this issue.
    Actually please check into your article and made sure don’t have div broken by readmore.
    Thank you
    ivan1012 Friend
    #433383
    ‘Yes actually I have read more buttons, but i dont know hot to check if they have broken the div.
    I updated necessary info …
    URL of the problem is this: http://www.novalica.com/novosti/kratka-pauza
    jooservices Friend
    #433502
    To check div broken. Please go to each article ( at least which one showing on your broken page ).
    Turn off editor and see if something like <div><readmore></div>
    Because readmore will break between open / close div.
    Thank you
    ivan1012 Friend
    #433529
    I have this line of code connected to read more:
    <hr id=”system-readmore” />
    jooservices Friend
    #433676
    Please just give me link of page be broken . I’ll go to fix it.
    Thank you
    ivan1012 Friend
    jooservices Friend
    #433814
    I’m checking your site. May i know have you customized your template or what did you do ? Because your html structure different with default template.
    This’s right structure
    <div id="ja-container" class="wrap ja-rir1">
    <div class="main clearfix">
    <div id="ja-mainbody" style="width:78%">
    <div id="ja-right" class="column sidebar" style="width:22%">
    </div>
    </div>
    And this’s your
    <div id="ja-wrapper">
    ivan1012 Friend
    #434055
    I have done customization but only visual, I haven’t touched the code? …
    jooservices Friend
    #434063
    What kind of code you want to touch ?
    ivan1012 Friend
    #434778
    <em>@jooservices 295016 wrote:</em><blockquote>Hi
    What kind of code you want to touch ?</blockquote>
    I’m not sure what do you mean with this? Is this some kind of irony?
    1. I just want the tweet and google +1 button to be like on the picture and
    2. to show the right sidebar next to to blog layout. Like I said in blog layout i use read more button … I gave U the site access but I also turned off the modules who should be on the position right of the menu item “kratka pauza” which shows in blog layout.
    I have done visual template customization that means only changes of colours backgrounds and margins etc. Recently I added two nnew module positions .slideshow and .slideshow2. Can you please help me resolve this 2 issues?
This topic contains 14 replies, has 3 voices, and was last updated by  ivan1012 12 years, 10 months ago.
