June 9, 2008 at 8:16 am #129453
I have layout problems with IE6 on Ja-Mageia…here you can see:
– no transparency
– wrong position of headerThis is IE6
This is FF
Can someone help? Thank’s a lot
GreetingsMenalto FriendMenalto
- May 2007
- 531 times in 361 posts
June 9, 2008 at 8:17 am #252652Live url? Template modifications?
June 9, 2008 at 8:38 am #252656URL is http://www.fink-ub.ch
no template modifications, i used the newest quickstart package from joomlart (Joomla! 1.5.x : Quickstart included Joomla! 1.5.3 +) My System ist PHP5.1.6, MySQL 5.0.22, Linux 2.6.18-53.1
June 10, 2008 at 9:05 am #252854Hi Menalto
Can you give me a idea where i can start to search for this problem?….I thank you and greetings
TLdmix123 Frienddmix123
- August 2008
August 20, 2008 at 4:16 pm #266315I had the same transparency issue with IE6. You need to make a correction in the template html.
Find this block of code:
<style type=”text/css”>
.clearfix {height: 1%;}
#ja-pathwaywrap {
background: none;
filter: progid:DXImageTransform.Microsoft.AlphaImageLoader(src=’templates/<?php echo $JAconfig->template; ?>/images/opaque-<?php echo $JAconfig->ja_color; ?>.png’, sizingMethod=’scale’);
</style>
<!–>There is an extra open parenthesis that needs to be removed. The original code has this:
……AlphaImageLoader((src=’templates/……..
Remove the extra “( ” after AlphaImageLoader and the transparency issues should work.
To fix the header position, go to the JANewsFlash module and change the height to 130.
Hope this helps!
1 user says Thank You to dmix123 for this useful post
August 29, 2008 at 11:15 am #267815Same issue here….
The fix with the transparency issue don’t work on my site: http://www.jk-wug.com
anisjolly Friendanisjolly
- April 2008
- 96 times in 55 posts
August 29, 2008 at 12:19 pm #267827try using Firebug in FF – this should help you sort out the css side of things.
- April 2008
August 29, 2008 at 12:21 pm #267828for the transparency – you need to install ie pngfix.
the website is using a png image for transparency and in ie it won’t work unless you install an ie pngfix transparency extension on your site.
November 3, 2008 at 9:40 pm #277962RE: iE6 issues:
after I Removed the extra “( ” after AlphaImageLoader per the suggestion above and adjusted JANewsFlash module to 130 high it worked under 1.5.7 on a clean install of the template.
This topic contains 9 replies, has 6 voices, and was last updated by duckcreek 16 years, 1 month ago.
