  • frostijonsson Friend
    #192579
    I am trying to upgrade a website to version 3.2 using this template. I moved the content on a clean installation of 3.2 and most things seem ok for a while when I’m adjusting modules and such and then suddenly the layout breaks and will not return to normal for me what ever I try.
    Everything was looking good until I enabled a module in footer position then I got this layout. And it does not help disabling it. I have tried starting over from a backup made early in the process and this keeps happening randomly. First time it was a custom HTML module in right column that I was changing when this same thing happened.
    I am using JA T3 Framework 2.6.8 and ja_edenite 2.5.4 and of course click the JAT3 clean cache (which I can’t disable by selecting developer mode – the setting will not save)
    It kind of looks like this may be the mobile look and I have tried to disable those but no change.
    Can you please help?
    1. mmr-bogg
    Ninja Lead Moderator
    #513823
    This template is not available for Joomla 3.2, we are still under process of updating our products to be compatible with this latest version of Joomla. Kindly wait for the updated package before upgrading Joomla 3.2 and check our blog post for updates news
    #514029
    Guys – please !
    I specifically renewed my membership this time to get the 3.x version of this template which is not only clearly marked as available it’s also awailable in the downloads. I have have wasted a lot ot time discovering that it is clearly not finished on your part but this answer is just unacceptable!
    Could you please provide the product as promised?
    1. ja-edenite3x
    #514069
    @frostijonsson: We are so sorry for the confusedness with the name of package, we will check and fix it soon.
    As I mentioned above, this template is not ready for Joomla 3.2 as its still under process of updating to this latest version of Joomla.
    For problem in your site, you can PM me admin and ftp account of your site, I will try to check it for you. Remember to take a backup of your site first
    #514257
    OK but as I understand it 3.2 is also a security update so it is very unfortunate that you are not up to date with your products. I was not aware the templates needed updating between 3.1 and 3.2 and have not had any problems updating other sites with templates from other sources.
    But OK if the update going to be available in the next few days I can hold off. But I hope it will be fully responsive and all functions working unlike previous versions. I did send the admin info in the first post. This installation is not the live website – the live website is giving us trouble which drove us to develope this update from 2.5
    #514411
    I’m so sorry about the problem on your site again. I can help you to take a closer look at your site. Please pm me FTP account. I will try to help you.
    #515356
    @frostijonsson: I have upgraded T3v2 framework on your site to latest verion(2.6.9) which is compatible with JOOMLA 3.2, the probem on your site is solved. Please check it again and let me know if it helps
    Haseeb Jamal Friend
    #515437
    Hi @ninja_Lead
    I have upgraded to the latest version of the JA T3 plugin v 2.6.9 but still the problem is not solved. i will PM you the site details so can you have a look at the site?
    Thanks in Advance
    #515510
    @haseebjamal: I have checked the problem on your site because your site is cached and I helped you to clear cache and changed some config from back-end template.
    Now, your site is working now. You can check it again
    #515787
    <em>@Ninja Lead 401857 wrote:</em><blockquote>@frostijonsson: I have upgraded T3v2 framework on your site to latest verion(2.6.9) which is compatible with JOOMLA 3.2, the probem on your site is solved. Please check it again and let me know if it helps</blockquote>
    Thanks Ninja Lead
    Unfortunately we ran out of time waiting for this solution and had to revert to working on and updating a previous 2.5 version of this website.
    However we are still interested in updating to Joomla 3.2 if possible. Is the updated (2.6.9) version of the T3v2 framework all that is needed? Do I not need a new version of ja_edenite for Joomla 3.2?
    I also have a question on the responsive-ness as I can not see the layout changing when I resize the browser window with the web you updated for us. Should the layout not respond to a shinking window like other modern responsive Joomla 3.x templates?
    Cheers
    #515803
    Released version on download page here only supports Joomla 3.1 but I have tested to upgrade from J2.5 or J3.1 to J3.2 and it’s working so well
    Before you proceed to upgrade your site to J3.2. Please take a BACKUP of your site first.
    This is document to upgrade JOOMLA on your site to J3.2 here
    After you finish updating JOOMLA. You have to get latest version of JAT3v2(2.6.9) framework plugin from JAEM(JA Extensions Manager component)/ You can have look at userguide JAEM for reference here
    onosan Friend
    #522367
    It works. Can confirm that it (so far) seems possible to upgrade without any problems 🙂
    the JAEM userguide link is broken though
    #522654
    About upgrading via JAEM component, just make sure that you check in:
    <blockquote>Admin area->Component->JA Extension Manager</blockquote>
    and provide account for “JoomlArt Updater Service” (Click on edit link of JoomlArt Updater Service on JAEM, you will see the form to enter your account info), then proceed upgrading.
This topic contains 13 replies, has 4 voices, and was last updated by  Ninja Lead 10 years, 11 months ago.
