  • bennyykh Friend
    #146434
    I want to ask how to adjust left and right column width of this template.
    I want to set left column width to 160px, and right column to 300px.
    beastmode54 JA JobBoard
    #325304
    Yes, i have the same question. Ive done this hundreds of times with other templates, but it seems with the new template structure I am un able to find the correct chunk of code.
    #325314
    looks like its in template/layout/blocks/ and which ever the right column is. Looks like it has its own .php file.
    Anonymous Moderator
    #325348
    Hi bennyykh
    – open templatesja_selenilayoutsblocksleft.php , find style=”width:<?php echo $l ?>%” and change to:
    style=”width:160px”
    – open templatesja_selenilayoutsblocksright.php , find style=”width:<?php echo $r ?>%” and change to:
    style=”width:300px”
    bennyykh Friend
    #325387
    <em>@JA Developer 155143 wrote:</em><blockquote>Hi bennyykh
    style=”width:160px”
    style=”width:300px”</blockquote>
    thanks, it worked 😉
    but after I changed it, there is a lof of space between the left column and the main content…. (pls see the attact file space.jpg)
    also, the right colume can’t fit into the position because it changed to 300px (bigger than the original one), pls see the attact file space2.jpg
    can u help me to solve it, thanks a lot :-[
    1. space
    2. space2
    lamvt Friend
    #325402
    Hi bennyykh.
    If you fixed your width collums, not good for you.
    Pls use my ideas:
    If you use your temlate width is 960px (check configurations of your config)
    left is 160px right is 300px so main about 500px
    left: 160/960= ~18%.
    right: 300/960=~32%
    main: so main is 50%
    Open yourtemplate: layouts/default.php Line 16: $this->_basewidth = 30;
    Changes it to $this->_basewidth = 32;
    Try to do it
    bennyykh Friend
    #325408
    yes, i also found it and it worked! 🙂
    changed the following 2 files:
    for right column: layouts/default.php >>>>> $this->_basewidth = 33.67;
    for left column: layouts/left-content.php >>>>> $this->_basewidth = 18.82;
    lamvt Friend
    #325410
    Best Answer
    rarunkumar7 Friend
    #325590
    The above said code is not there in the new version of the template(1.1 version).Please help me to reduce the right column size to 20%.
    Arun
    bennyykh Friend
    #325591
    you can find it at templatesja_selenilayoutsdefault.php
    line 16: this->_basewidth = 30;
    just change 30 to other value u want
    rarunkumar7 Friend
    #325594
    Thanks Benny.How do I enable both left and right columns with middle column as content for this template.
    Arun
This topic contains 11 replies, has 5 voices, and was last updated by  rarunkumar7 15 years ago.
