  • nicoberry54 Friend
    #131476
    I’ve done a little bit of modifying to the Teline II template I installed and now any modules I put in the “left” or “right” positions jump down to the bottom just above the footer.
    Any ideas why?
    The URL for the site is: http://www.coldgettindumb.com
    The module that is currently in the “left” position is the banner ad with the T-shirt that says “get dumb” at the top of it.
    It is supposed to be up at the top next to the main banner with the Boombox character.
    Thanks.
    Menalto Friend
    #262856
    First off, give us a full list over modifications you have done to the template?
    And try to turn off the modules you have below mainbody(i belive its user8 and user9 and see if that helps out also).
This topic contains 2 replies, has 2 voices, and was last updated by  Menalto 16 years, 5 months ago.
