  • maughns Friend
    #118868
    modules loaded in the left column overlaps the left edge of the template. see http://www.elmont.org. Can someone direct me to how this can be fixed?
    jwm931 Friend
    #214803
    Are you using Joomla 1.5?
    maughns Friend
    #214832
    Thanks for your prompt reply. no, I am using mambo 4.6.1
    orhaniman Friend
    #251719
    i am using joomla 1.5.3
    and i worked a little of the template css code to correct the left alignment but couldnt be successfull
    here the attachment is:
    need urgent help on it…regards,
    tchmultimedia Friend
    #309853
    1 way to get around it is to modify the background image – to increase the width… it’s dodgy but it works…
This topic contains 5 replies, has 4 voices, and was last updated by  tchmultimedia 15 years, 5 months ago.
