February 22, 2007 at 10:14 pm #118909
First of all happy new year….
As far as I see the length of the left column is arranged according to main content area. This leaves some white space in the bottom of left column when right column is longer than the main content area. Overall border is OK, only left column finishes at the point where main content finishes.
Thanks in advance,
Serkancssyeah Moderatorcssyeah
- June 2006
- 121 times in 81 posts
February 23, 2007 at 9:52 am #214910Hi serkany,
You need enable javascript on your browse.
Khanh Le ModeratorKhanh Le
- November 2013
- 203 times in 131 posts
February 23, 2007 at 11:02 am #214913JA Kruger use javascript to adjust the height of left-main-right column. Please following instruction to fix the problem.
In template index.php file, search following code:
window.onload=function(){
<?php
if ( $ja_left && $ja_right ) {
Nifty("div#ja-mainbodywrap,div#ja-rightcol","none same-height");
Nifty("div#ja-mainbody,div#ja-leftcol","none same-height");
<?php
} elseif ( $ja_left ) {
Nifty("div#ja-mainbody-fr,div#ja-leftcol","none same-height");
<?php
} elseif ( $ja_right ) {
<?php
Replace with:
var mainbodywrap = document.getElementById ("ja-content<?php echo $divid ?>");
var spotlight = document.getElementById ("ja-spotlight");
var mainbody = document.getElementById ("ja-mainbody<?php echo $divid ?>");
var rightcol = document.getElementById ("ja-rightcol");
var leftcol = document.getElementById ("ja-leftcol");
var pathway = document.getElementById ("ja-pathway");
var banner = document.getElementById ("ja-banner");var wh = mainbodywrap.scrollHeight;
if (rightcol && rightcol.scrollHeight > wh) wh = rightcol.scrollHeight;
var slh = spotlight ? spotlight.scrollHeight : 0;
var pwh = pathway ? pathway.scrollHeight : 0;
var bh = banner ? banner.scrollHeight : 0;
//if (mainbodywrap) mainbodywrap.style.height = wh + "px";
if (rightcol) rightcol.style.height = wh + "px";
if (mainbody) mainbody.style.height = (wh - slh - pwh - bh - 30) + "px";
if (leftcol) leftcol.style.height = (wh - slh - pwh - bh - 10) + "px";
February 24, 2007 at 10:25 pm #214963Hi,
Actually javascript is enabled in my browser. . I think the problem is not javascript because the template can arrange the heights in all cases except right column height is more than the main content and left column height.
I applied this change to index.php but I had problems with a component that uses xajax. To make a comment it opens a comment area with ajax and when I make the above change the height of the main content is not increased accordingly which makes the comment form unreachable. I prefer to arrange the heights of my columns so that no problem occurs.
Thanks for the replies.
Regards,
SerkanMarch 11, 2007 at 10:27 pm #215538Hi Again,
This left column height is causing problems for me. I thought that I could arrange it with modules but always some cases occur so that the lower part of the left column is white.
Have a look at this link:
http://www.geziyorumlari.com/index.php?option=com_jreviews&Itemid=160It looks like a simple error which can be corrected easily but how:) As I said before the left column arranges its height according to the main content area without considering the right column height. But the border that covers the left column and main content is working OK so left column should use the same logic to work properly. I would appreciate any help in this.
Thanks in advance,
SerkanMarch 19, 2007 at 3:07 pm #216121Hi Guys,
I really need your help for this issue. The error messages of my main component (Jreviews) are not displayed appropriately, most probably because of this left column issue. Also I have some problems about the color of the text in the CB tabs. Some of them are white and background is light blue, so the text is almost invisible for mamblog and joomlaboard tabs. I guess it’s easy to solve but not for me:)
Regards,
SerkanKhanh Le ModeratorKhanh Le
- November 2013
March 20, 2007 at 2:59 am #216142Hi serkany,
You could apply the above code to ajust the height of columns after the ajax updates content. Please modify above code to:
function ajustHeight() {
}window.onload = ajustHeight;
Then you could call the function ajustHeight() after ajax update comments.
March 21, 2007 at 3:49 pm #216244Hi,
Here is the link without implementing the code change. this is the live system.
http://www.geziyorumlari.com/index.php?option=com_jreviews&Itemid=160And here is a link where I implemented that change. This is the development system
http://www.geziyorumlari.com/development/index.php?option=com_jreviews&Itemid=160As you can see, left column can arrange the length. That’s quite good.
But when I try to enter a new content I got a problem with the new index.php. See it in the development system:
http://www.geziyorumlari.com/development/index.php?option=com_jreviews&task=new&dir=14§ion=7&cat=66&Itemid=160The form goes down but the template doesn’t. It works normal without implementing the form:
http://www.geziyorumlari.com/index.php?option=com_jreviews&task=new&dir=14§ion=7&cat=66&Itemid=160So looks like I need a combination of these two:)
And in both cases the error messages are not displayed. I’m not sure whether this is because of the template or not but you can see it by just pressing “Gönder” button without entering anything. Nothing or only a few letters of the message is displayed.
Regards,
Serkan -
This topic contains 8 replies, has 3 voices, and was last updated by serkany 17 years, 8 months ago.
