April 17, 2011 at 2:01 am #162865
Hi, I had change some part of my site to left-content-right, from template manager/Global. But wen I create a menu module and set it on left position, its apears with a top margin. (sorry my english itsnt good)
You can see it in my site here!Thanks a lot. Pretty awesome Template!!
aman204 Friendaman204
- January 2010
- 418 times in 356 posts
April 17, 2011 at 6:10 am #386701Please disable css compression in template parameters to give in right file and line reference
April 17, 2011 at 10:25 pm #386752It doesnt work. I disable in template manager but doesnt work. Look this.
This is my configuration.:((
- January 2010
April 18, 2011 at 7:00 am #386806Comment it out ::
#ja-mainbody {template.css (line 442)
padding-top: 20px;
}like this::
/*#ja-mainbody {template.css (line 442)
padding-top: 20px;
}*/and then to have, main body area seen as earlier, add this at end of template.css file:::
#ja-main{padding-top:20px;}
- January 2010
April 19, 2011 at 10:51 am #387072<em>@carlamarlan 234983 wrote:</em><blockquote>Ok. Now its ok, but your recomendation change another page from site that I have made with JA Tabs Plugin Here.. What can I do now?
Thanks.</blockquote>
You can make use of page class suffix functionality to have the padding set right for specific menu item
After you have added the suggested code in other post, You can try and add this at end of template.css file ::
.tabs #ja-main{padding-top:0;}
along with tabs entered as page class suffix
AuthorPostsViewing 6 posts - 1 through 6 (of 6 total)This topic contains 6 replies, has 2 voices, and was last updated by aman204 13 years, 8 months ago.
left-content-right top margin issue
