  • sponni Friend
    #133101
    Hi again, I looked through this forum and did not see this issue come up. On this page…
    http://www.stjarnan-karfa.is/index.php?option=com_content&view=article&id=8&Itemid=7
    when mouse is rolled over the left menu there is a problem with something overshadowing the left side of the menu box. Could someone help me with this please?
    Best wishes,
    Bragi
    mfcphil Friend
    #269490
    Hi Bragi
    Read through this post and try the solution
    http://www.joomlart.com/forums/topic/problem-in-ie7/
    You can fix it following way below :
    add following code section :
    ul.menu {
    ul.menu li {
    width: 99%;
    to the template.css file in templatesja_faguscss folder.
    Hope this helps
    sponni Friend
    #269576
    Heyja… this worked wonders ๐Ÿ™‚ thanks a lot for taking the time !
    sponni Friend
    #269713
    Hi again, I noticed another problem with the menu width, and since i am getting such great respons from here it seems the easyest way to go. If you click this link…
    you can see that thr right side of the left menu is cut off. Any ideas?
    Best wishes,
    Bragi
    mfcphil Friend
    #269728
    Think you will find that is simply down to the number of letters in your links….the image is being cut slightly if your links were smaller in length then the full box would be visable….I THINK!!
    Try losing the -eldri and the -yngri and see if this solves it
    mfcphil Friend
    #269733
    mmmm looking at your Blaรฐamannafundur KKร รญ dag would suggest I’m mistaken :confused:
    mfcphil Friend
    #269734
    Here is what I would do to solve it.
    Copy your Karfan.is module.
    manualy enter all the required link and link them to their destination page
    Unglingaflokkur
    Drengjaflokkur
    11. flokkur
    9. flokkur
    8. flokkur
    7. flokkur
    Minni bolti – eldri
    Minni bolti – yngri
    save it and call it something else, publist to left and all should be well ๐Ÿ˜‰
    sponni Friend
    #269735
    Hi, karfan.is modul is a rss feed…
    But i think this only happened when I added that code (posted earlier in this thread) to fix the previous problem I had here heh ๐Ÿ™‚ Wonder if it could be something with that?
    This happens with all the menu models I am using….
    http://www.stjarnan-karfa.is/index.php?option=com_content&view=section&layout=blog&id=1&Itemid=22
    http://www.stjarnan-karfa.is/index.php?option=com_content&view=article&id=15&Itemid=18
    Best wishes,
    Bragi
    mfcphil Friend
    #269764
    Well you could cut the earlir code…I would consider changing your menu type to Son of Suckerfish (number 2 on menu options) this will allow you to create some nicer additions to your lefthand side like mine. ๐Ÿ˜€
    sponni Friend
    #270092
    I cut the code out and the boxes were fixed… so it is something with the code. Now the original problem as first reported in this thread is back ๐Ÿ™‚ http://www.stjarnan-karfa.is/index.php?option=com_content&view=article&id=15&Itemid=18
    Also the box on the front page with the rss feed is broken now… hehe I am not understanding this ๐Ÿ™‚ Anyone have any ideas?
    Best wishes,
    Bragi
    mfcphil Friend
    #270109
    Did you consider changing your menu to son of suckerfish? Your menu’s would not be on the left hand side and you would not have the problem
    mfcphil Friend
    #270232
    try this code
    ul.menu li {
    display : block;
    sponni Friend
    #273853
    Hi again,
    I decided to put this on hold for a few days hoping it would solve it self by some miracle ๐Ÿ™‚ But no.. it didn’t. So I am back on square 1 with this matter.
    This newest code you suggested did not change anything. But the original code in the beginning of this thread works on solving the original problem but now the right side of the box is cut off, as can be seen here… http://www.stjarnan-karfa.is/index.php?option=com_content&view=article&id=15&Itemid=18
    I hope someone can solve this for me.. I am getting close to launch deadline on this project :(.
    Best wishes,
    Bragi
    sponni Friend
    #273854
    Hmmm it seems I have solved it by changing that original code.
    It was…
    ul.menu {
    ul.menu li {
    width: 99%;
    But I changed the witdh to 90%. It seems ok now.. I hope it stays that way ๐Ÿ™‚
    Bragi
    mfcphil Friend
    #273856
    Well done Bragi ๐Ÿ˜€
This topic contains 15 replies, has 2 voices, and was last updated by  mfcphil 16 years, 3 months ago.
