  • boerenooi Friend
    #162380
    If I choose a horizontal menu in Ja purity ii, then the drop down works, but when I make the menu sit on the left position, it doesn’t come out. Is there an easy way to sort this out?
    Thank you kindly
    Ninja Lead Moderator
    #385856
    Hi boerenooi,
    The dropdowns only appear in Mega menu which is the “horizontal menu”, when you make it to the left position, its rendered as a normal joomla menu and hence does not have the dropdowns. If you want to have dropdowns on the left menu you might try some menu extensions on JED.
This topic contains 2 replies, has 2 voices, and was last updated by  Ninja Lead 13 years, 8 months ago.
