  • abadius Friend
    #192570
    Hello. I need to reduce the space between top menu and the position of the first module, to show a slideshow with less height and position the first content up in a few pixels.
    Whats it the correct file to touch this?.
    Best Regards.
    MoonSailor Friend
    #513679
    You can create “templates/ja_obelisk/css/custom.css” file
    Add new script inside it
    .loaded .t3-slideshow{
    margin-bottom:-40%; ( You can change to your desired value here )
This topic contains 2 replies, has 2 voices, and was last updated by  MoonSailor 11 years, 1 month ago.
