  • xuxo Friend
    #200143
    Hi there,
    Sh404sef is generating hundreds of SEF URL’s like: en/en/Page-33941.html as those you can see in the screenshot.
    The non-SEF URL for this example is: index.php?option=com_content&Itemid=703&lang=en&limitstart=135760&view=featured
    Note that, in my website, the itemid 703 ​​corresponds to a menu item. In particular the Home item of the English menu.
    The only difference in all hundreds SEF URLs generated is the limitstart parameter.
    Please can you give me a clue on why this is happening?
    Thank you
    joan
    1. muchas_SEF
    Ninja Lead Moderator
    #544107
    Your concern is related to SH404sef component rather than our template. You should also raise this in the Sh404sef component forum, you might get better answers there.
    xuxo Friend
    #544338
    <em>@Ninja Lead 439000 wrote:</em><blockquote>Your concern is related to SH404sef component rather than our template. You should also raise this in the Sh404sef component forum, you might get better answers there.</blockquote>
    Hi @ninja Lead I did it, I submitted the question in the sh404SEF forum, and Jimie’s answer was clear:
    <blockquote>sh404SEF does not generates urls, sh404sef simply rewrite non-sef urls found on your website into sef urls.
    Those urls seams to be pagination urls, which means probably your website homepage displays a list of lots articles, which displayed in many pages.</blockquote>
    So, the point is that some piece of the system is generating pagination related non-SEF URL’s. But we don’t have a lot of articles in our site, Our more populated category can reach 4 or 5 pages on the category list, but never forty or fivety thousands, which is the case.
    Note that in the non-SEF URL’s generated, the only diference is the limitstart parameter. Some examples below
    SEF URL ———————>non-SEF URL
    en/en/Page-10421.html—>index.php?option=com_content&Itemid=703&lang=en&limitstart=41680&view=featured
    en/en/Page-10523.html—>index.php?option=com_content&Itemid=703&lang=en&limitstart=42090&view=featured
    en/en/Page-13406.html—>index.php?option=com_content&Itemid=703&lang=en&limitstart=53620&view=featured
    en/en/Page-16676.html—>index.php?option=com_content&Itemid=703&lang=en&limitstart=66700&view=featured
    en/en/Page-18753.html—>index.php?option=com_content&Itemid=703&lang=en&limitstart=75010&view=featured
    … and hundreds of url’s like this
    Note that always the itemid is 703, which is a menu item. It’s the Home Page item of the English Menu of our site. And apparently the configuration of such item is correct.
    I’ve been reading in different forums and seems that there is some problem related to pagination in some platform with Joomla 3 and T3. Probably this is affecting our site
    The problem is that the set Joomla + JA Brisk is creating hundreds of unexpected URL’s, and not sh404SEF
    Please, any help will be appreciated
    joan
    #544413
    Can you send me link to see the pagination problem in Joomla 3 and T3? In T3 framework we do not change anything related to generating URL’s in joomla core.
    I see your site is using old version T3 framework and I just upgraded it to new version on your site, please clear Url manager and test with new version T3 framework, if you still face the problem, you can pm me FTP account of your site. I shall help you check further.
    xuxo Friend
    #544428
    Hi @ninja Lead
    You can check the posts I’ve been reading regarding pagination problems with T3+k2+sh404SEF here, and here. Really don’t know if this is a cause of all our problems
    The T3 version we’ve running is 2.3.0
    I’ll send a PM with our ftp credentials
    Thanks a lot for your time and help
    Joan
    #544431
    Hi Joan,
    I could not create new folder from your hosting, I got this problem “test: Disk quota exceeded”, please check and pm me FTP account again.
    xuxo Friend
    #544435
    Hi @ninja Lead
    I tried the ftp credentials I sent with different ftp clients like FileZilla, even IE, and no problem to create new folders.
    Please try again
    Thanks a lot
    Joan
    #544554
    Hi Joan,
    I just upgraded latest T3 framework(v2.3.1) on your site and included the fix bug pagination problems with T3+k2+sh404SEF here of you mentioned. But I see some cache was conflicted in your site. Can you set username/password included thread become super admin? I will help you to set some cache configuration on your site.
    xuxo Friend
    #544594
    Thanks @ninja Lead , now the user/password declared in the thread has SuperUser Rights. Thanks again for your help.
    Probably this cache problem is the cause of our menu associations problem reported in this thread. I hope so
    I deeply appreciate your help
    Joan
    xuxo Friend
    #544790
    Hi @ninja Lead .
    Have you been able to have a look at the cache problem on our website?
    I would be very, very grateful if you can do it. Thanks again !
    #544806
    I got this problem when I tried to disable System – Cache from Plugin manager of your site
    <blockquote>Edit state is not permitted</blockquote>
    See the screenshot
    You will see both caches from front-end site shlib – Db query cache and programming library from sh404SEF and System – Cache from joomla default, please disable System – Cache
    1. caching_back_end_site
    xuxo Friend
    #545009
    Hi @ninja Lead , I’be been looking for System Cache in the plugins section and it was disabled
    I didn’t changed nothing
    Let me know if you need something more from my side
    Thanks a lot for your interest
    Joan
    1. cache
    xuxo Friend
    #545025
    Hi @ninja Lead ,
    I set to OFF disabled cache on Global Configuration > System > Cache Settings > Cache > OFF Cache Disabled
    Now, my setup regarding cache is as follows:
    • Global Configuration > System > Cache Settings > Cache > set to “OFF Cache Disabled”
    • Extensions > Plugin Manager > System Cache … Disabled
    • Extensions > Plugin Manager > shlib – Db query cache and programming library … Enabled
    With this setup, the Menu Associations problem reported in this thread seems to be solved. The question now is … disabling core caches will penalize my website performance? or shlib will take care now of that performance?
    Unfortunately, with this setup still persist the creation of unexpected non-SEF URLs. No idea what module or plugin is generating such quantity (hundreds in 24 hours) of unexpected URL’s:
    sef URL——————-non-sef URL
    pagina-2.html————index.php?option=com_content&Itemid=913&lang=es&limit=4&limitstart=4&view=featured
    pagina-39981.html—–index.php?option=com_content&Itemid=913&lang=es&limitstart=159920&view=featured
    pagina-4516.html——-index.php?option=com_content&Itemid=913&lang=es&limitstart=18060&view=featured
    pagina-46673.html—–index.php?option=com_content&Itemid=913&lang=es&limitstart=186690&view=featured
    pagina-48663.html—–index.php?option=com_content&Itemid=913&lang=es&limitstart=194650&view=featured
    pagina-8996.html——-index.php?option=com_content&Itemid=913&lang=es&limitstart=35980&view=featured
    where 913 is the itemid of a menu item, in particular the Home Page of the Main Menu Spanish
    Please any help will be deeply appreciated
    Joan
    #545035
    Hi Joan,
    I tried to help you to check all cases on JA Brisk template, but I’m sure from T3 framework and JA Brisk template could not define any generate link override with JOOMLA default.
    <blockquote>With this setup, the Menu Associations problem reported in this thread seems to be solved. The question now is … disabling core caches will penalize my website performance? or shlib will take care now of that performance?</blockquote>
    I see in sh404SEF component uses “site shlib – Db query cache“.
    Can you contact sh404SEF component and ask them to find out the problem from Url manager in sh404SEF ?
    If you need to help any thing about our product, please do not hesitate contact to us
This topic contains 14 replies, has 2 voices, and was last updated by  Ninja Lead 10 years, 5 months ago.
