June 4, 2009 at 4:59 pm #141695
How do you link to a page created outside of the templete appear in a frame. Then have it link to a page and have that page appear in the same window. I am using a php module that lets me display a unique php script or form. I have a form that needs the resulting page to appear after submission.
hanifahmed Friendhanifahmed
- August 2008
- 141 times in 110 posts
- August 2008
June 4, 2009 at 6:07 pm #306941Did it help? Always remember to mark best answer!
theprofessor Friendtheprofessor
- March 2009
- 64 times in 18 posts
June 4, 2009 at 6:36 pm #306950<em>@aaron126 131486 wrote:</em><blockquote>How do you link to a page created outside of the templete appear in a frame. Then have it link to a page and have that page appear in the same window. I am using a php module that lets me display a unique php script or form. I have a form that needs the resulting page to appear after submission.</blockquote>
I also found an extension at joomla.org that does this. It keeps everything in the same window and does not use an iFrame.
i’ll try to find it. Wrapper may suffice, but if you need more than that…check it out.
- August 2008
June 4, 2009 at 7:16 pm #306956<em>@theprofessor 131519 wrote:</em><blockquote>I also found an extension at joomla.org that does this. It keeps everything in the same window and does not use an iFrame.
i’ll try to find it. Wrapper may suffice, but if you need more than that…check it out.</blockquote>
Are you stalking me? loltheprofessor Friendtheprofessor
- March 2009
June 4, 2009 at 8:29 pm #306961<em>@hanifahmed 131526 wrote:</em><blockquote>Are you stalking me? lol</blockquote>
LOL — don’t flatter yourself.Not sure where you would get that from.
Anyways, the extension I was refering to in my post is Ninja Loader. Haven’t tried it but looks like it could be an interesting alternative to a wrapper…which if i’m not mistaken uses an iframe.
http://extensions.joomla.org/extensions/style-&-design/popups-&-iframes/5959/details
This topic contains 6 replies, has 3 voices, and was last updated by theprofessor 15 years, 6 months ago.
