webdojo Friend
webdojo
- May 2015
- 3 times in 3 posts
March 22, 2016 at 9:48 am #903242Hello guys, after joomla upgrade (3.5.0 vr) the link to return to the home page doesn’t work. The problem is
<a data-itemid="101" href="" title="AAAA">
(new) instead of
<a data-itemid="101" href="/" title="AAAA">
(old, correct) What’s the correct point to be changed?
thanks, Dario
March 22, 2016 at 11:20 am #903299Hi
Do not update the live site if you are facing problem with latest J3.5 .
Team is working on the template updates for latest Joomla and it will be released soon .
You can edit your first post and submit the site details with screenshot of issue . I will take a look in it.1 user says Thank You to Pankaj Sharma for this useful post
webdojo Friendwebdojo
- May 2015
March 22, 2016 at 2:16 pm #903360Thanks Pankaj
March 22, 2016 at 3:38 pm #903389Hi
I did not found the site details (super user details with url) in first post . Kindly post them via private reply .webdojo Friendwebdojo
- May 2015
March 22, 2016 at 4:19 pm #903423the url is on the snapshot 😉
SU credentials are not necessary for this problem.Pankaj Sharma ModeratorPankaj Sharma
October 6, 2016 at 7:02 pm #974221Same issue here. Joomla 3.6.2
October 7, 2016 at 1:31 am #974249The problem was already solved in updated version of template kindly update the template in t3 latest version .
October 7, 2016 at 1:49 pm #974443I already upgraded yesterday the T3 and I installed yesterday the template. What else should I do?
Thanks in advance.
October 7, 2016 at 2:14 pm #974447Send me your site super user detail with admin path using private Reply I will check it
October 10, 2016 at 8:10 am #974942I’ve seen that the issue is generated when SEF is off.
October 10, 2016 at 8:30 am #974954Hi
canu Send me your site super user detail with admin path using private Reply so that i can take a look on it ?October 10, 2016 at 9:00 am #974961This reply has been marked as private.Pankaj Sharma ModeratorPankaj Sharma
October 10, 2016 at 9:39 am #974978Hi
i just check the template fresh package and its working fine with the SEF OFF .
http://prntscr.com/cs04m9
I am not sure its Joomla issue or template when site is multilanguage , you can switch the template to Joomla default for a menu item and see are you getting same result ?
In this case its issue in the Joomla when SEF is off and site in multilanguage it redirecting on same page .AuthorPostsViewing 14 posts - 1 through 14 (of 14 total)This topic contains 13 replies, has 3 voices, and was last updated by Pankaj Sharma 8 years, 2 months ago.
Link to home page problem after joomla update
