  • jakubd Friend
    #181615
    I’m using JA Teline IV version 2.5.0 with Joomla 2.5.6. For some reason the empty area around the linkable images is linkable. If you visit the site, you can view an example here. The area around the images is linkable when only the image itself should be linkable. This happens in every article. Any ideas?
    jakubd Friend
    #470799
    This problem seems to occur in Firefox and Safari.
    HeR0 Friend
    #470828
    Hi Jakubd
    It is in article content, so you can change link when you edit article.
    Regards,
    jakubd Friend
    #471041
    I understand that you can change the link in the article content, but why is the white space around the image linkable? I only want the image to be clickable, not the space around it.
    HeR0 Friend
    #471053
    Hi Jakubd,
    Go to Backend > Content manager > edit ‘Momentum’ Listening Session Live On Twitter With Stevie Stone article > double click to image in content then change value of Alignment attribute to left
    Regards,
This topic contains 5 replies, has 2 voices, and was last updated by  HeR0 12 years, 2 months ago.
