  • gegit Friend
    #122277
    I just realized that I’m having a problem with all links on the site (frontside). Getting a 404 error with all links. Basically, the home page is the only thing that works. I added an item to the site with the same ending result. Any ideas of why?
    TomC Moderator
    #227918
    Sounds like it may be an issue with your particular host server.
    gegit Friend
    #227920
    Well all links related to anything other than the Joomla! links are not working correctly. So it seems there is some sort of conflict with JA Larix and Virtuemart. The products display on home page, even the newly added product for testing but clicking on any of them results in a 404 error. My site is: http://www.gegit.net if anyone wants a closer look.
    TomC Moderator
    #227925
    Do you have VirtueMart installed on your server? Seems that might be the issue – as there is no flypage to connect to when one clicks on the product image. Again, just a guess, but you may want to make sure you actually have VirtueMart correctly installed.
    gegit Friend
    #227942
    <em>@tcraw1010 25550 wrote:</em><blockquote>Do you have VirtueMart installed on your server? Seems that might be the issue – as there is no flypage to connect to when one clicks on the product image. Again, just a guess, but you may want to make sure you actually have VirtueMart correctly installed.</blockquote>
    I wish it was that easy, but I’m able to access the VirtueMart administration and I have also added a product which does not link either. I’ll follow the flypage lead to see if I can figure out something that way.
This topic contains 5 replies, has 2 voices, and was last updated by  gegit 17 years, 4 months ago.
