January 31, 2013 at 12:24 pm #184555
I am using the latest version of J2.5 and Onepage.
What I would like to do is use the onepage template as a portfolio so when I click the PORTFOLIO menu item it scrolls down to that section. That part is working fine. The question I have is now I would like to click on a specific portfolio item and be taken to that specific article, without any pop up. How can this be done?
When I change the template layout from onepage to default this works, but other aspects don’t Do I need to add a position on the onepage layout? If so, is there documentation on how to do this?
Thanks.
Stork11 FriendStork11
- March 2011
- 431 times in 393 posts
February 1, 2013 at 8:14 am #481962Hello zbolt,
First, you should set “Show Popup” setting of JA Content Popup module to “No”.
Secondly, you should create a menu for the category that contains the article. If not, item will open in the home page.
Hope this helps.
Regards.
jorgitomarianao Friendjorgitomarianao
- December 2012
February 1, 2013 at 11:20 am #482004Stork11 FriendStork11
- March 2011
February 2, 2013 at 7:51 am #482134Did you upgrade to latest version of JA Content Popup module?
AuthorPostsViewing 4 posts - 1 through 4 (of 4 total)This topic contains 4 replies, has 3 voices, and was last updated by Stork11 11 years, 10 months ago.
Linking to article and adding module positions on Onepage
