aussom Friend
aussom
- August 2011
- 2 times in 1 posts
October 19, 2011 at 8:44 am #169819Hi there,
I have a problem with URLs and links to categories/articles in News Pro module.
Links to the sample articles are as:
/entertainment/entertainment-news/movies/315-1803159158but when i created a new categories and articles, the url will be, for example:
/177-news/news-thai/470-big-flood-in-thailand
it contains item id for the category and article which is different from the sample data.When i clicked on the link, it went to nowhere but the homepage!!
I have enabled “Search Engine Friendly URLs”, “Use URL rewriting” and changed htaccess.txt to .htaccess but I still have problem with the links that go nowhere.
Can anyone help me please:((
jooservices Friendjooservices
- October 2014
- 1245 times in 1121 posts
October 19, 2011 at 9:04 am #420163Hi,
Can you PM me your FTP account for check?
Viet Vujooservices Friendjooservices
- October 2014
October 19, 2011 at 10:04 am #420179Hi
It’s hard to say anything until now. Would you mind try to turn off SEF and check if it’s working well ?
Thank you
Viet Vuaussom Friendaussom
- August 2011
October 19, 2011 at 10:27 am #420182Hi Viet Vu,
I’ve tried to turn off SEF as you suggested but it doesn’t work still.
If I rename the sample category, the link works, but if I create new category, it doesn’t work. Unfortunately I’ve deleted most of sample categories.
I have sent you PM my acc to view my website.
If you look at “Life and Style” topic, everthing works well because it is the sample data.
If you check on “Travel” topic, it works well also because I’ve just add new subcategories while keeping the parent category(travel) unchanged.
But “News” topic is the new category I’ve added after remove the sample “News” category. This one doesn’t work.aussom Friendaussom
- August 2011
October 21, 2011 at 10:38 pm #420794Still waiting for suggestion. :((
- October 2014
October 22, 2011 at 12:04 am #420796Good morning
I saw your trouble. I’m trying to find out reason.
Please moment
Thank you
- October 2014
October 22, 2011 at 12:12 am #420797Yup got why
#1. You Home menu is 490 and in this template Home menu wont display component.
#2. You have created new Category but have no menu created / pointed to that Category -> J! will get current itemid ( Home – 490 ) to use -> Home menu won’t display component.
#3. Solution:
Please create Category for “root” of each Category you want to use. I’ve created News Category for you.
Thank you
Viet Vu1 user says Thank You to jooservices for this useful post
aussom Friendaussom
- August 2011
October 22, 2011 at 12:40 am #420801I got it work!!!!! Thank you very much. I didn’t know before that I have to create a menu for each category too.
Thank you again for your help :-*
- October 2014
October 24, 2011 at 7:19 am #421143Hi,
You’re welcome. 🙂
Viet Vu -
This topic contains 9 replies, has 2 voices, and was last updated by jooservices 13 years, 2 months ago.
