cantabriadeportiva Friend
cantabriadeportiva
- June 2011
- 4 times in 1 posts
April 17, 2013 at 2:26 pm #186860Hello!
I’m using K2 and JA Disqus Debate Echo Plugin. I need to move the Plugin to the bottom of the page, because I want the writer description above the comments.
I’ve already edit the item.php file (/templates/ja_argo/html/com_k2/ja_argo) and I moved this code
<!-- Plugins: AfterDisplayContent -->
<?php echo $this->item->event->AfterDisplayContent; ?>to the bottom of the file. It works, but I have a small problem, there is a grey line that I can’t delete:
This is the code of the item.php
<?php
* @version $Id: item.php 1812 2013-01-14 18:45:06Z lefteris.kavadas $
* @package K2
* @author JoomlaWorks http://www.joomlaworks.net
* @copyright Copyright (c) 2006 - 2013 JoomlaWorks Ltd. All rights reserved.
* @license GNU/GPL license: http://www.gnu.org/copyleft/gpl.html
*/// no direct access
defined('_JEXEC') or die;?>
<?php if(JRequest::getInt('print')==1): ?>
<!-- Print button at the top of the print page only -->
<a class="itemPrintThisPage" rel="nofollow" href="#" onclick="window.print();return false;">
<span><?php echo JText::_('K2_PRINT_THIS_PAGE'); ?></span>
</a>
<?php endif; ?><div id="k2Container" class="itemView<?php echo ($this->item->featured) ? ' itemIsFeatured' : ''; ?><?php if($this->item->params->get('pageclass_sfx')) echo ' '.$this->item->params->get('pageclass_sfx'); ?>">
<!-- Start K2 Item Layout -->
<span id="startOfPageId<?php echo JRequest::getInt('id'); ?>"></span><!-- Plugins: BeforeDisplay -->
<?php echo $this->item->event->BeforeDisplay; ?><!-- K2 Plugins: K2BeforeDisplay -->
<?php echo $this->item->event->K2BeforeDisplay; ?><div class="itemHeader">
<?php if($this->item->params->get('itemCategory')): ?>
<!-- Item category -->
<div class="itemCategory">
<span><?php echo JText::_('K2_PUBLISHED_IN'); ?></span>
<a href="<?php echo $this->item->category->link; ?>"><?php echo $this->item->category->name; ?></a>
</div>
<?php endif; ?>
<?php if($this->item->params->get('itemTitle')): ?>
<!-- Item title -->
<h2 class="itemTitle">
<?php if(isset($this->item->editLink)): ?>
<!-- Item edit link -->
<span class="itemEditLink">
<a class="modal" rel="{handler:'iframe',size:{x:990,y:550}}" href="<?php echo $this->item->editLink; ?>">
<?php echo JText::_('K2_EDIT_ITEM'); ?>
</a>
</span>
<?php endif; ?><?php echo $this->item->title; ?>
<?php if($this->item->params->get('itemFeaturedNotice') && $this->item->featured): ?>
<!-- Featured flag -->
<span>
<sup>
<?php echo JText::_('K2_FEATURED'); ?>
</sup>
</span>
<?php endif; ?>
</h2>
<?php endif; ?>
</div><!-- Plugins: AfterDisplayTitle -->
<?php echo $this->item->event->AfterDisplayTitle; ?><!-- K2 Plugins: K2AfterDisplayTitle -->
<?php echo $this->item->event->K2AfterDisplayTitle; ?><?php if(
$this->item->params->get('itemFontResizer') ||
$this->item->params->get('itemPrintButton') ||
$this->item->params->get('itemEmailButton') ||
$this->item->params->get('itemSocialButton') ||
$this->item->params->get('itemVideoAnchor') ||
$this->item->params->get('itemImageGalleryAnchor') ||
$this->item->params->get('itemCommentsAnchor')
<div class="itemToolbar">
<?php if($this->item->params->get('itemAuthor')): ?>
<!-- Item Author -->
<span class="itemAuthor">
<small><?php echo JText::_('TPL_BY'); ?></small>
<?php if(empty($this->item->created_by_alias)): ?>
<a rel="author" href="<?php echo $this->item->author->link; ?>"><?php echo $this->item->author->name; ?></a>
<?php else: ?>
<?php endif; ?>
</span>
<?php endif; ?>
<?php if($this->item->params->get('itemDateCreated')): ?>
<!-- Date created -->
<span class="itemDateCreated">
<small><?php echo JText::_('TPL_ON'); ?></small><?php echo JHTML::_('date', $this->item->created , JText::_('DATE_FORMAT_LC3')); ?>
</span>
<?php endif; ?><?php if($this->item->params->get('itemHits')): ?>
<!-- Item Hits -->
<span class="itemHits">
<?php echo $this->item->hits; ?> <small><?php echo JText::_('K2_TIMES'); ?></small>
</span>
<?php endif; ?><!-- Plugins: BeforeDisplayContent -->
<?php echo $this->item->event->BeforeDisplayContent; ?><?php if($this->item->params->get('itemTwitterButton',1) || $this->item->params->get('itemFacebookButton',1) || $this->item->params->get('itemGooglePlusOneButton',1)): ?>
<!-- Social sharing -->
<div class="itemSocialSharing"><?php if($this->item->params->get('itemTwitterButton',1)): ?>
<!-- Twitter Button -->
<div class="itemTwitterButton">
<a href="https://twitter.com/share" class="twitter-share-button" data-count="horizontal"<?php if($this->item->params->get('twitterUsername')): ?> data-via="<?php echo $this->item->params->get('twitterUsername'); ?>"<?php endif; ?>>
<?php echo JText::_('K2_TWEET'); ?>
</a>
<script type="text/javascript" src="//platform.twitter.com/widgets.js"></script>
</div>
<?php endif; ?><?php if($this->item->params->get('itemFacebookButton',1)): ?>
<!-- Facebook Button -->
<div class="itemFacebookButton">
<div id="fb-root"></div>
(function(d, s, id) {
var js, fjs = d.getElementsByTagName(s)[0];
if (d.getElementById(id)) return;
js = d.createElement(s); js.id = id;
js.src = "//connect.facebook.net/en_US/all.js#xfbml=1";
fjs.parentNode.insertBefore(js, fjs);
}(document, 'script', 'facebook-jssdk'));
</script>
<div class="fb-like" data-send="false" data-width="200" data-show-faces="true"></div>
</div>
<?php endif; ?><?php if($this->item->params->get('itemGooglePlusOneButton',1)): ?>
<!-- Google +1 Button -->
<div class="itemGooglePlusOneButton">
<g:plusone annotation="inline" width="120"></g:plusone>
(function() {
window.___gcfg = {lang: 'en'}; // Define button default language here
var po = document.createElement('script'); po.type = 'text/javascript'; po.async = true;
po.src = 'https://apis.google.com/js/plusone.js';
var s = document.getElementsByTagName('script')[0]; s.parentNode.insertBefore(po, s);
</script>
</div>
<?php endif; ?><div class="clr"></div>
</div>
<?php endif; ?>
<ul>
<?php if($this->item->params->get('itemFontResizer')): ?>
<!-- Font Resizer -->
<li>
<span class="itemTextResizerTitle"><?php echo JText::_('K2_FONT_SIZE'); ?></span>
<a href="#" id="fontDecrease">
<span><?php echo JText::_('K2_DECREASE_FONT_SIZE'); ?></span>
<img src="<?php echo JURI::root(true); ?>/components/com_k2/images/system/blank.gif" alt="<?php echo JText::_('K2_DECREASE_FONT_SIZE'); ?>" />
</a>
<a href="#" id="fontIncrease">
<span><?php echo JText::_('K2_INCREASE_FONT_SIZE'); ?></span>
<img src="<?php echo JURI::root(true); ?>/components/com_k2/images/system/blank.gif" alt="<?php echo JText::_('K2_INCREASE_FONT_SIZE'); ?>" />
</a>
</li>
<?php endif; ?><?php if($this->item->params->get('itemPrintButton') && !JRequest::getInt('print')): ?>
<!-- Print Button -->
<li>
<a class="itemPrintLink" rel="nofollow" href="<?php echo $this->item->printLink; ?>" onclick="window.open(this.href,'printWindow','width=900,height=600,location=no,menubar=no,resizable=yes,scrollbars=yes'); return false;">
<span><?php echo JText::_('K2_PRINT'); ?></span>
</a>
</li>
<?php endif; ?><?php if($this->item->params->get('itemEmailButton') && !JRequest::getInt('print')): ?>
<!-- Email Button -->
<li>
<a class="itemEmailLink" rel="nofollow" href="<?php echo $this->item->emailLink; ?>" onclick="window.open(this.href,'emailWindow','width=400,height=350,location=no,menubar=no,resizable=no,scrollbars=no'); return false;">
<span><?php echo JText::_('K2_EMAIL'); ?></span>
</a>
</li>
<?php endif; ?><?php if($this->item->params->get('itemSocialButton') && !is_null($this->item->params->get('socialButtonCode', NULL))): ?>
<!-- Item Social Button -->
<li>
<?php echo $this->item->params->get('socialButtonCode'); ?>
</li>
<?php endif; ?><?php if($this->item->params->get('itemVideoAnchor') && !empty($this->item->video)): ?>
<!-- Anchor link to item video below - if it exists -->
<li>
<a class="itemVideoLink k2Anchor" href="<?php echo $this->item->link; ?>#itemVideoAnchor"><?php echo JText::_('K2_MEDIA'); ?></a>
</li>
<?php endif; ?><?php if($this->item->params->get('itemImageGalleryAnchor') && !empty($this->item->gallery)): ?>
<!-- Anchor link to item image gallery below - if it exists -->
<li>
<a class="itemImageGalleryLink k2Anchor" href="<?php echo $this->item->link; ?>#itemImageGalleryAnchor"><?php echo JText::_('K2_IMAGE_GALLERY'); ?></a>
</li>
<?php endif; ?><?php if($this->item->params->get('itemCommentsAnchor') && $this->item->params->get('itemComments') && ( ($this->item->params->get('comments') == '2' && !$this->user->guest) || ($this->item->params->get('comments') == '1')) ): ?>
<!-- Anchor link to comments below - if enabled -->
<li>
<?php if(!empty($this->item->event->K2CommentsCounter)): ?>
<!-- K2 Plugins: K2CommentsCounter -->
<?php echo $this->item->event->K2CommentsCounter; ?>
<?php else: ?>
<?php if($this->item->numOfComments > 0): ?>
<a class="itemCommentsLink k2Anchor" href="<?php echo $this->item->link; ?>#itemCommentsAnchor">
<span><?php echo $this->item->numOfComments; ?></span> <?php echo ($this->item->numOfComments>1) ? JText::_('K2_COMMENTS') : JText::_('K2_COMMENT'); ?>
</a>
<?php else: ?>
<span><?php echo $this->item->numOfComments; ?></span> <?php echo JText::_('K2_COMMENT'); ?>
</a>
<?php endif; ?>
<?php endif; ?>
</li>
<?php endif; ?>
</ul>
</div>
<?php endif; ?><div class="itemBody">
<!-- K2 Plugins: K2BeforeDisplayContent -->
<?php echo $this->item->event->K2BeforeDisplayContent; ?><?php if($this->item->params->get('itemImage') && !empty($this->item->image)): ?>
<!-- Item Image -->
<div class="itemImageBlock">
<span class="itemImage">
<a class="modal" rel="{handler: 'image'}" href="<?php echo $this->item->imageXLarge; ?>" title="<?php echo JText::_('K2_CLICK_TO_PREVIEW_IMAGE'); ?>">
<img src="<?php echo $this->item->image; ?>" alt="<?php if(!empty($this->item->image_caption)) echo K2HelperUtilities::cleanHtml($this->item->image_caption); else echo K2HelperUtilities::cleanHtml($this->item->title); ?>" style="width:<?php echo $this->item->imageWidth; ?>px; height:auto;" />
</a>
</span><?php if($this->item->params->get('itemImageMainCaption') && !empty($this->item->image_caption)): ?>
<!-- Image caption -->
<span class="itemImageCaption"><?php echo $this->item->image_caption; ?></span>
<?php endif; ?><?php if($this->item->params->get('itemImageMainCredits') && !empty($this->item->image_credits)): ?>
<!-- Image credits -->
<span class="itemImageCredits"><?php echo $this->item->image_credits; ?></span>
</div>
<?php endif; ?><?php if(!empty($this->item->fulltext)): ?>
<?php if($this->item->params->get('itemIntroText')): ?>
<!-- Item introtext -->
<div class="itemIntroText">
<?php echo $this->item->introtext; ?>
</div>
<?php endif; ?>
<?php if($this->item->params->get('itemFullText')): ?>
<!-- Item fulltext -->
<div class="itemFullText">
<?php echo $this->item->fulltext; ?>
</div>
<?php endif; ?>
<?php else: ?>
<!-- Item text -->
</div>
<?php endif; ?><?php if($this->item->params->get('itemExtraFields') && count($this->item->extra_fields)): ?>
<!-- Item extra fields -->
<div class="itemExtraFields">
<h3><?php echo JText::_('K2_ADDITIONAL_INFO'); ?></h3>
<ul>
<?php foreach ($this->item->extra_fields as $key=>$extraField): ?>
<?php if($extraField->value != ''): ?>
<li class="<?php echo ($key%2) ? "odd" : "even"; ?> type<?php echo ucfirst($extraField->type); ?> group<?php echo $extraField->group; ?>">
<?php if($extraField->type == 'header'): ?>
<h4 class="itemExtraFieldsHeader"><?php echo $extraField->name; ?></h4>
<?php else: ?>
<span class="itemExtraFieldsLabel"><?php echo $extraField->name; ?>:</span>
<span class="itemExtraFieldsValue"><?php echo $extraField->value; ?></span>
<?php endif; ?>
</li>
<?php endif; ?>
<?php endforeach; ?>
</ul>
</div>
<?php endif; ?><?php if($this->item->params->get('itemRating') || $this->item->params->get('itemDateModified') && intval($this->item->modified)!=0): ?>
<div class="itemContentFooter">
<?php if($this->item->params->get('itemDateModified') && intval($this->item->modified)!=0): ?>
<!-- Item date modified -->
<span class="itemDateModified">
<small><?php echo JText::_('K2_LAST_MODIFIED_ON'); ?></small> <?php echo JHTML::_('date', $this->item->modified, JText::_('DATE_FORMAT_LC3')); ?>
</span>
<?php endif; ?><?php if($this->item->params->get('itemRating')): ?>
<!-- Item Rating -->
<div class="itemRatingBlock">
<span><?php echo JText::_('K2_RATE_THIS_ITEM'); ?></span>
<div class="itemRatingForm">
<ul class="itemRatingList">
<li class="itemCurrentRating" id="itemCurrentRating<?php echo $this->item->id; ?>" style="width:<?php echo $this->item->votingPercentage; ?>%;"></li>
<li><a href="#" rel="<?php echo $this->item->id; ?>" title="<?php echo JText::_('K2_1_STAR_OUT_OF_5'); ?>" class="one-star">1</a></li>
<li><a href="#" rel="<?php echo $this->item->id; ?>" title="<?php echo JText::_('K2_2_STARS_OUT_OF_5'); ?>" class="two-stars">2</a></li>
<li><a href="#" rel="<?php echo $this->item->id; ?>" title="<?php echo JText::_('K2_3_STARS_OUT_OF_5'); ?>" class="three-stars">3</a></li>
<li><a href="#" rel="<?php echo $this->item->id; ?>" title="<?php echo JText::_('K2_4_STARS_OUT_OF_5'); ?>" class="four-stars">4</a></li>
<li><a href="#" rel="<?php echo $this->item->id; ?>" title="<?php echo JText::_('K2_5_STARS_OUT_OF_5'); ?>" class="five-stars">5</a></li>
</ul>
<div id="itemRatingLog<?php echo $this->item->id; ?>" class="itemRatingLog"><?php echo $this->item->numOfvotes; ?></div>
</div>
</div>
<?php endif; ?>
</div>
<?php endif; ?><!-- K2 Plugins: K2AfterDisplayContent -->
<?php echo $this->item->event->K2AfterDisplayContent; ?><div class="clr"></div>
</div><?php if($this->item->params->get('itemTags') || $this->item->params->get('itemAttachments')): ?>
<div class="itemLinks"><?php if($this->item->params->get('itemTags') && count($this->item->tags)): ?>
<!-- Item tags -->
<div class="itemTagsBlock">
<span><?php echo JText::_('K2_TAGGED_UNDER'); ?></span>
<ul class="itemTags">
<?php foreach ($this->item->tags as $tag): ?>
<li><a href="<?php echo $tag->link; ?>"><?php echo $tag->name; ?></a></li>
</ul>
</div>
<?php endif; ?><?php if($this->item->params->get('itemAttachments') && count($this->item->attachments)): ?>
<!-- Item attachments -->
<div class="itemAttachmentsBlock">
<span><?php echo JText::_('K2_DOWNLOAD_ATTACHMENTS'); ?></span>
<ul class="itemAttachments">
<?php foreach ($this->item->attachments as $attachment): ?>
<li>
<a title="<?php echo K2HelperUtilities::cleanHtml($attachment->titleAttribute); ?>" href="<?php echo $attachment->link; ?>"><?php echo $attachment->title; ?></a>
<?php if($this->item->params->get('itemAttachmentsCounter')): ?>
<span>(<?php echo $attachment->hits; ?> <?php echo ($attachment->hits==1) ? JText::_('K2_DOWNLOAD') : JText::_('K2_DOWNLOADS'); ?>)</span>
<?php endif; ?>
</li>
</ul>
</div>
</div>
<?php endif; ?><?php if($this->item->params->get('itemAuthorBlock') && empty($this->item->created_by_alias)): ?>
<!-- Author Block -->
<div class="itemAuthorBlock"><?php if($this->item->params->get('itemAuthorImage') && !empty($this->item->author->avatar)): ?>
<img class="itemAuthorAvatar" src="<?php echo $this->item->author->avatar; ?>" alt="<?php echo K2HelperUtilities::cleanHtml($this->item->author->name); ?>" />
<?php endif; ?><div class="itemAuthorDetails">
<h3 class="itemAuthorName">
</h3><?php if($this->item->params->get('itemAuthorDescription') && !empty($this->item->author->profile->description)): ?>
<p><?php echo $this->item->author->profile->description; ?></p>
<?php endif; ?><?php if($this->item->params->get('itemAuthorURL') && !empty($this->item->author->profile->url)): ?>
<span class="itemAuthorUrl"><?php echo JText::_('K2_WEBSITE'); ?> <a rel="me" href="<?php echo $this->item->author->profile->url; ?>" target="_blank"><?php echo str_replace('http://','',$this->item->author->profile->url); ?></a></span>
<?php endif; ?><?php if($this->item->params->get('itemAuthorEmail')): ?>
<span class="itemAuthorEmail"><?php echo JText::_('K2_EMAIL'); ?> <?php echo JHTML::_('Email.cloak', $this->item->author->email); ?></span>
<!-- K2 Plugins: K2UserDisplay -->
<?php echo $this->item->event->K2UserDisplay; ?></div>
</div>
<?php endif; ?><?php if($this->item->params->get('itemAuthorLatest') && empty($this->item->created_by_alias) && isset($this->authorLatestItems)): ?>
<!-- Latest items from author -->
<div class="itemAuthorLatest">
<h3><?php echo JText::_('K2_LATEST_FROM'); ?> <?php echo $this->item->author->name; ?></h3>
<ul>
<?php foreach($this->authorLatestItems as $key=>$item): ?>
<li class="<?php echo ($key%2) ? "odd" : "even"; ?>">
<a href="<?php echo $item->link ?>"><?php echo $item->title; ?></a>
</li>
</ul>
</div>
Note regarding 'Related Items'!
If you add:
- the CSS rule 'overflow-x:scroll;' in the element div.itemRelated {…} in the k2.css
- the class 'k2Scroller' to the ul element below
- the classes 'k2ScrollerElement' and 'k2EqualHeights' to the li element inside the foreach loop below
- the style attribute 'style="width:<?php echo $item->imageWidth; ?>px;"' to the li element inside the foreach loop below
...then your Related Items will be transformed into a vertical-scrolling block, inside which, all items have the same height (equal column heights). This can be very useful if you want to show your related articles or products with title/author/category/image etc., which would take a significant amount of space in the classic list-style display.
?><?php if($this->item->params->get('itemRelated') && isset($this->relatedItems)): ?>
<!-- Related items by tag -->
<div class="itemRelated">
<h3><?php echo JText::_("K2_RELATED_ITEMS_BY_TAG"); ?></h3>
<ul>
<?php foreach($this->relatedItems as $key=>$item): ?>
<li class="<?php echo ($key%2) ? "odd" : "even"; ?>"><?php if($this->item->params->get('itemRelatedTitle', 1)): ?>
<a class="itemRelTitle" href="<?php echo $item->link ?>"><?php echo $item->title; ?></a>
<?php endif; ?><?php if($this->item->params->get('itemRelatedCategory')): ?>
<div class="itemRelCat"><?php echo JText::_("K2_IN"); ?> <a href="<?php echo $item->category->link ?>"><?php echo $item->category->name; ?></a></div>
<?php endif; ?><?php if($this->item->params->get('itemRelatedAuthor')): ?>
<div class="itemRelAuthor"><?php echo JText::_("K2_BY"); ?> <a rel="author" href="<?php echo $item->author->link; ?>"><?php echo $item->author->name; ?></a></div>
<?php endif; ?><?php if($this->item->params->get('itemRelatedImageSize')): ?>
<img style="width:<?php echo $item->imageWidth; ?>px;height:auto;" class="itemRelImg" src="<?php echo $item->image; ?>" alt="<?php K2HelperUtilities::cleanHtml($item->title); ?>" />
<?php endif; ?><?php if($this->item->params->get('itemRelatedIntrotext')): ?>
<div class="itemRelIntrotext"><?php echo $item->introtext; ?></div>
<?php endif; ?><?php if($this->item->params->get('itemRelatedFulltext')): ?>
<div class="itemRelFulltext"><?php echo $item->fulltext; ?></div>
<?php endif; ?><?php if($this->item->params->get('itemRelatedMedia')): ?>
<?php if($item->videoType=='embedded'): ?>
<div class="itemRelMediaEmbedded"><?php echo $item->video; ?></div>
<?php else: ?>
<div class="itemRelMedia"><?php echo $item->video; ?></div>
<?php endif; ?>
<?php endif; ?><?php if($this->item->params->get('itemRelatedImageGallery')): ?>
<div class="itemRelImageGallery"><?php echo $item->gallery; ?></div>
<?php endif; ?>
</li>
<li class="clr"></li>
</ul>
</div>
<?php if($this->item->params->get('itemVideo') && !empty($this->item->video)): ?>
<!-- Item video -->
<a name="itemVideoAnchor" id="itemVideoAnchor"></a><div class="itemVideoBlock">
<h3><?php echo JText::_('K2_MEDIA'); ?></h3><?php if($this->item->videoType=='embedded'): ?>
<div class="itemVideoEmbedded">
<?php echo $this->item->video; ?>
</div>
<?php else: ?>
<span class="itemVideo"><?php echo $this->item->video; ?></span>
<?php endif; ?><?php if($this->item->params->get('itemVideoCaption') && !empty($this->item->video_caption)): ?>
<span class="itemVideoCaption"><?php echo $this->item->video_caption; ?></span>
<?php endif; ?><?php if($this->item->params->get('itemVideoCredits') && !empty($this->item->video_credits)): ?>
<span class="itemVideoCredits"><?php echo $this->item->video_credits; ?></span>
</div>
<?php endif; ?><?php if($this->item->params->get('itemImageGallery') && !empty($this->item->gallery)): ?>
<!-- Item image gallery -->
<a name="itemImageGalleryAnchor" id="itemImageGalleryAnchor"></a>
<div class="itemImageGallery">
<h3><?php echo JText::_('K2_IMAGE_GALLERY'); ?></h3>
<?php echo $this->item->gallery; ?>
</div>
<?php endif; ?><?php if($this->item->params->get('itemNavigation') && !JRequest::getCmd('print') && (isset($this->item->nextLink) || isset($this->item->previousLink))): ?>
<!-- Item navigation -->
<div class="itemNavigation">
<span class="itemNavigationTitle"><?php echo JText::_('K2_MORE_IN_THIS_CATEGORY'); ?></span><?php if(isset($this->item->previousLink)): ?>
<a class="itemPrevious" href="<?php echo $this->item->previousLink; ?>">
« <?php echo $this->item->previousTitle; ?>
</a>
<?php endif; ?><?php if(isset($this->item->nextLink)): ?>
<a class="itemNext" href="<?php echo $this->item->nextLink; ?>">
<?php echo $this->item->nextTitle; ?> »
</a>
<?php endif; ?></div>
<?php endif; ?><!-- Plugins: AfterDisplay -->
<?php echo $this->item->event->AfterDisplay; ?><!-- K2 Plugins: K2AfterDisplay -->
<?php echo $this->item->event->K2AfterDisplay; ?><?php if($this->item->params->get('itemComments') && ( ($this->item->params->get('comments') == '2' && !$this->user->guest) || ($this->item->params->get('comments') == '1'))): ?>
<!-- K2 Plugins: K2CommentsBlock -->
<?php echo $this->item->event->K2CommentsBlock; ?>
<?php endif; ?><?php if($this->item->params->get('itemComments') && ($this->item->params->get('comments') == '1' || ($this->item->params->get('comments') == '2')) && empty($this->item->event->K2CommentsBlock)): ?>
<!-- Item comments -->
<a name="itemCommentsAnchor" id="itemCommentsAnchor"></a><div class="itemComments">
<?php if($this->item->params->get('commentsFormPosition')=='above' && $this->item->params->get('itemComments') && !JRequest::getInt('print') && ($this->item->params->get('comments') == '1' || ($this->item->params->get('comments') == '2' && K2HelperPermissions::canAddComment($this->item->catid)))): ?>
<!-- Item comments form -->
<div class="itemCommentsForm">
<?php echo $this->loadTemplate('comments_form'); ?>
</div>
<?php endif; ?><?php if($this->item->numOfComments>0 && $this->item->params->get('itemComments') && ($this->item->params->get('comments') == '1' || ($this->item->params->get('comments') == '2'))): ?>
<!-- Item user comments -->
<h3 class="itemCommentsCounter">
</h3><ul class="itemCommentsList">
<?php foreach ($this->item->comments as $key=>$comment): ?>
<li class="<?php echo ($key%2) ? "odd" : "even"; echo (!$this->item->created_by_alias && $comment->userID==$this->item->created_by) ? " authorResponse" : ""; echo($comment->published) ? '':' unpublishedComment'; ?>"><span class="commentLink">
<a href="<?php echo $this->item->link; ?>#comment<?php echo $comment->id; ?>" name="comment<?php echo $comment->id; ?>" id="comment<?php echo $comment->id; ?>">
<?php echo JText::_('K2_COMMENT_LINK'); ?>
</a>
</span><?php if($comment->userImage): ?>
<img src="<?php echo $comment->userImage; ?>" alt="<?php echo JFilterOutput::cleanText($comment->userName); ?>" width="<?php echo $this->item->params->get('commenterImgWidth'); ?>" />
<?php endif; ?><span class="commentDate">
<?php echo JHTML::_('date', $comment->commentDate, JText::_('K2_DATE_FORMAT_LC2')); ?>
</span><span class="commentAuthorName">
<?php echo JText::_('K2_POSTED_BY'); ?>
<?php if(!empty($comment->userLink)): ?>
<a href="<?php echo JFilterOutput::cleanText($comment->userLink); ?>" title="<?php echo JFilterOutput::cleanText($comment->userName); ?>" target="_blank" rel="nofollow">
<?php echo $comment->userName; ?>
</a>
<?php else: ?>
<?php endif; ?>
</span><p><?php echo $comment->commentText; ?></p>
<?php if($this->inlineCommentsModeration || ($comment->published && ($this->params->get('commentsReporting')=='1' || ($this->params->get('commentsReporting')=='2' && !$this->user->guest)))): ?>
<span class="commentToolbar">
<?php if($this->inlineCommentsModeration): ?>
<?php if(!$comment->published): ?>
<a class="commentApproveLink" href="<?php echo JRoute::_('index.php?option=com_k2&view=comments&task=publish&commentID='.$comment->id.'&format=raw')?>"><?php echo JText::_('K2_APPROVE')?></a>
<?php endif; ?><a class="commentRemoveLink" href="<?php echo JRoute::_('index.php?option=com_k2&view=comments&task=remove&commentID='.$comment->id.'&format=raw')?>"><?php echo JText::_('K2_REMOVE')?></a>
<?php endif; ?><?php if($comment->published && ($this->params->get('commentsReporting')=='1' || ($this->params->get('commentsReporting')=='2' && !$this->user->guest))): ?>
<a class="modal" rel="{handler:'iframe',size:{x:560,y:480}}" href="<?php echo JRoute::_('index.php?option=com_k2&view=comments&task=report&commentID='.$comment->id)?>"><?php echo JText::_('K2_REPORT')?></a>
<?php endif; ?><?php if($comment->reportUserLink): ?>
<a class="k2ReportUserButton" href="<?php echo $comment->reportUserLink; ?>"><?php echo JText::_('K2_FLAG_AS_SPAMMER'); ?></a>
<?php endif; ?></span>
</li>
</ul><div class="itemCommentsPagination">
<?php echo $this->pagination->getPagesLinks(); ?>
</div>
<?php endif; ?><?php if($this->item->params->get('commentsFormPosition')=='below' && $this->item->params->get('itemComments') && !JRequest::getInt('print') && ($this->item->params->get('comments') == '1' || ($this->item->params->get('comments') == '2' && K2HelperPermissions::canAddComment($this->item->catid)))): ?>
</div>
<?php endif; ?><?php $user = JFactory::getUser(); if ($this->item->params->get('comments') == '2' && $user->guest): ?>
<div><?php echo JText::_('K2_LOGIN_TO_POST_COMMENTS'); ?></div>
<?php endif; ?>
<?php echo $this->item->event->AfterDisplayContent; ?><?php if(!JRequest::getCmd('print')): ?>
<div class="itemBackToTop">
<a class="k2Anchor" href="<?php echo $this->item->link; ?>#startOfPageId<?php echo JRequest::getInt('id'); ?>">
<?php echo JText::_('K2_BACK_TO_TOP'); ?>
</a>
</div>
</div>
<!-- End K2 Item Layout -->
Does anyone know how to delete this line??
Thank so much!
cantabriadeportiva Friendcantabriadeportiva
- June 2011
April 17, 2013 at 3:58 pm #490194Other thing, Can I put the article tags in the same line that “rate this article” (instead “last modified…”) ??? 🙂
MoonSailor FriendMoonSailor
- November 2011
- 248 times in 223 posts
April 18, 2013 at 7:17 am #490270Hi,
<blockquote>
</blockquote>Please open file “templates/ja_argo/less/joomla.less” and file “templates/ja_argo/css/template.css” add css code to below content of file :
[PHP]
#idc-container .idc-foot{
border:none !important;
[/PHP]<blockquote>
</blockquote>open file “templates/ja_argo/html/com_k2/ja_argo/item.php” find code
[PHP]
<?php if($this->item->params->get(‘itemRating’) || $this->item->params->get(‘itemDateModified’) && intval($this->item->modified)!=0): ?>
<div class=”itemContentFooter”>
<?php if($this->item->params->get(‘itemDateModified’) && intval($this->item->modified)!=0): ?>
<!– Item date modified –>
<span class=”itemDateModified”>
<small><?php echo JText::_(‘K2_LAST_MODIFIED_ON’); ?></small> <?php echo JHTML::_(‘date’, $this->item->modified, JText::_(‘DATE_FORMAT_LC3’)); ?>
</span>
<?php endif; ?><?php if($this->item->params->get(‘itemRating’)): ?>
<!– Item Rating –>
<div class=”itemRatingBlock”>
<span><?php echo JText::_(‘K2_RATE_THIS_ITEM’); ?></span>
<div class=”itemRatingForm”>
<ul class=”itemRatingList”>
<li class=”itemCurrentRating” id=”itemCurrentRating<?php echo $this->item->id; ?>” style=”width:<?php echo $this->item->votingPercentage; ?>%;”></li>
<li><a href=”#” rel=”<?php echo $this->item->id; ?>” title=”<?php echo JText::_(‘K2_1_STAR_OUT_OF_5’); ?>” class=”one-star”>1</a></li>
<li><a href=”#” rel=”<?php echo $this->item->id; ?>” title=”<?php echo JText::_(‘K2_2_STARS_OUT_OF_5’); ?>” class=”two-stars”>2</a></li>
<li><a href=”#” rel=”<?php echo $this->item->id; ?>” title=”<?php echo JText::_(‘K2_3_STARS_OUT_OF_5’); ?>” class=”three-stars”>3</a></li>
<li><a href=”#” rel=”<?php echo $this->item->id; ?>” title=”<?php echo JText::_(‘K2_4_STARS_OUT_OF_5’); ?>” class=”four-stars”>4</a></li>
<li><a href=”#” rel=”<?php echo $this->item->id; ?>” title=”<?php echo JText::_(‘K2_5_STARS_OUT_OF_5’); ?>” class=”five-stars”>5</a></li>
</ul>
<div id=”itemRatingLog<?php echo $this->item->id; ?>” class=”itemRatingLog”><?php echo $this->item->numOfvotes; ?></div>
</div>
</div>
<?php endif; ?>
<div class=”clr”></div>
</div>
<?php endif; ?>
[/PHP]and you can put “article tags” in here.
- June 2011
April 18, 2013 at 4:00 pm #490329Thanks!
There is something more. I would like to change the order of the k2 plugins. The order now is Tags, Author Desc. and Related articles by tag, and I need Author, Tags, and Related.
I tried several times but I have a code error with the sentence <?php endif; ?>
Could you help me??
Thanks!
zomidaily Friendzomidaily
- March 2013
- 9 times in 1 posts
April 19, 2013 at 6:01 pm #490483Hi…
Would you mind to share your live site? I think your idea would have a great look.
I notice that Argo template has something totally different with others, the K2 Disqus comment and AllVideos plugin are shown below down at the bottom after the Related items.
<em>@cantabriadeportiva 369543 wrote:</em><blockquote>Thanks!
Could you help me??
Thanks!</blockquote>
- March 2013
April 19, 2013 at 6:03 pm #490484Hi…
Could you help me??
AuthorPostsViewing 6 posts - 1 through 6 (of 6 total)This topic contains 6 replies, has 3 voices, and was last updated by zomidaily 11 years, 7 months ago.
Little problem changing the position of ‘AfterDisplayContent’
