  • audisport Friend
    #157932
    Hi guys,
    Thanks a lot for this great template!
    I have a little problem in IE8, the width seems to be different compared to IE7 or Firefox. Do you have an idea on what should be changed?
    Please see the pic to understand my standings.
    Thanks in advance for your assistance 😉
    1. ja-anion_ie8
    Phill Moderator
    #368826
    It looks fine in the demo on my IE8 machine. Have you made any modifications? Please post a link to the affected page.
    audisport Friend
    #368828
    The site I’m actually making is at http://www.vagracing.ch. I’ve made some changes in CSS and tried to put it back to normal but the error seems to stay, kind of 1px difference…
    I’ve just checked the demo site and have also the same problem 😉
    Thanks a lot for your help.
    My IE version is 8.0.6001
    1. ja-anion_ie8_joomlartdemosite
    Phill Moderator
    #368833
    I cannot replicate on the demo site but can see the problem on yours. However, I can only view in IE8 using a tool on my linux box. I do not have a windows machine to do any debug until I get back to work next week. Maybe someone else can now take a look in the mean time.
    audisport Friend
    #370547
    Hi Phill, Hi Guys,
    Any news regarding this problem with IE8?
    Thanks a lot!
    Hayden A Friend
    #370791
    you open file templates/ja_anion/css/mod_jaslideshow2.css and find line
    [PHP].ja-slidewrap { border: 0; overflow: hidden; }[/PHP]and change to :
    [PHP].ja-slidewrap { border: 0; overflow: hidden; margin-left: -1 !important }[/PHP]
    audisport Friend
    #370823
    Solved! Thanks a lot!
    :laugh:
    audisport Friend
    #371210
    Sorry guys, finally this solve the problem with the compatibility mode of IE8 activated but in real IE8 the problem subists…
    I’m continue looking to find a solution if in the meantime you find something else, please let us know, that will be good to have this great template full compatible with all browser 😉
    audisport Friend
    #371214
    I’ve found this reading the source of the page, could that be a possibily (width 99.99%)? If its possible which file should I look?
    <blockquote> <!– MAIN CONTAINER –>
    <div id=”ja-container” class=”wrap ja-mf”>
    <div class=”main clearfix”>
    <div class=”top”><div class=”tl”></div><div class=”tr”></div></div>
    <div class=”mid clearfix”><div class=”ml”></div>
    <div class=”main-inner clearfix”>
    <div id=”ja-mainbody” style=”width:99.99%”>
    <!– CONTENT –>
    <div id=”ja-main” style=”width:99.99%”>
    <div class=”inner clearfix”>
    <div id=”ja-contentwrap” class=”clearfix “>
    <div id=”ja-content” class=”column” style=”width:99.99%”>
    <div id=”ja-current-content” class=”column” style=”width:99.99%”>
    <div id=”ja-content-main” class=”ja-content-main clearfix”>
    </blockquote>
    Thanks a lot for your assistance,
    Hayden A Friend
    #371405
    <blockquote>I’ve found this reading the source of the page, could that be a possibily (width 99.99%)? If its possible which file should I look?
    <!– CONTENT –>
    Thanks a lot for your assistance, </blockquote>If you change width: 99.99% your site layout will break.
    audisport Friend
    #371589
    Hi all,
    Txs for the hint, I did’nt changed anything. That was just an idea.
    However your template is still showing a difference even in your template demo, did you find a solution to solve this 1px left difference in IE8 :(( ?
    Thanks a lot for your assistance, it’s a great template but this difference breaks a little bit the design and my visitors are at 80% using IE8…
    Hayden A Friend
    #371814
    you create new file template-ie8.css in folder templatesja_anioncss
    you open file template-ie8.css add new line
    [PHP]#ja-main .inner {
    margin-left: -1px !important;
    }[/PHP]then it will fix bug only in IE8
    audisport Friend
    #371904
    Apparently Solved!!!
    Thanks a lot!
This topic contains 13 replies, has 3 voices, and was last updated by  audisport 13 years, 11 months ago.
