  • Pankaj Sharma Moderator
    #1017907
    Kindly add read more button in the article editor so that article will not show the intro text again.
    Or you can open the Menu options > Show intro text > Hide.
    and it will hide the double text.
    Hope it helps.
    alteskino Friend
    #1018009
    Then he does not show me the more read button and it is displayed too much!
    1. Bildschirmfoto-2017-03-14-um-08.46.57
    alteskino Friend
    #1018012
    #1018116
    To make the plugin work kindly apply the suggestion given Here the suggestion for the same matter.
    alteskino Friend
    #1018161
    But it is not so! Could not you even look at that?
    #1018264
    The suggestion is for the same issue sir. May i know on which article you have this issue? Load module not working.
    alteskino Friend
    #1018279
    #1018416
    I fixed the problem directory on your site.
    You can see my change in
    "/html/com_content/article/default.php"
    line 195
    <?php echo $this->item->fulltext; ?>
    change to
     <?php echo $this->item->text; ?>
    Best Regards
    alteskino Friend
    #1018500
    Could you look again, but now the article is displayed twice under each other!
    alteskino Friend
    #1018502
    Ok, I’ve found the error myself.
    Thank you for your help!
This topic contains 10 replies, has 2 voices, and was last updated by  alteskino 7 years, 8 months ago.
The topic ‘Load module does not work’ is closed to new replies.
