  • kanenses Friend
    #189297
    As my subject tell, loadposition not work as well the widgekit contents :s
    {loadposition xxxxxxx} or [widgetkit id=6]
    Stop of work on joomla 2.5.13 and Brisk 1.0.5
    Anyone have the same issue? How can I fix this issue?
    Ninja Lead Moderator
    #500462
    Please check Content – Load Modules plugin on your site is enabling or not. I have tested it with format {loadposition sidebar-2}, it is working fine on Joomla 2.5.13
    kanenses Friend
    #500504
    Thanks for your reply.
    Yes the Load Modules are enable.
    Oh man strange this 🙁
    But nothing appens. What do you suggest? Reinstall joomla and save my DB and custom changes on template?
    Thanks,
    #500548
    So that I can take a look and try to assist, please pm me URL of your site and admin access, i shall check it for you.
This topic contains 4 replies, has 2 voices, and was last updated by  Ninja Lead 11 years, 5 months ago.
