June 11, 2011 at 8:04 am #165105
Hi all! I’m new on Joomlart and very enjoy JA Teline IV template. Before update my current old (non Joomlart template) template, I wanted to test template on subdomain. So, and after installing and configuring it I saw that speed of load is very low. For example – here is result by GMetrix (YSlow+Pagespeed). So and I think that time in this service is very high, I always have 6-8 seconds length of load.
The question is – how can I improve load speed of my site? TIA.
Sherlock FriendSherlock
- 2478 times in 2162 posts
June 13, 2011 at 4:58 am #396017hi idealist,
To improve the load speed of your site you can try to enable caching in your global configuration as well as in the template setting.
If doing that make no sense then i think the problem is related to your hosting and kindly contacting your hosting manager to get a hand.pritam Friendpritam
- April 2011
- 125 times in 113 posts
June 13, 2011 at 9:57 am #396069Hello idealist,
To Load speed problem
For increase the Load speed in your website You need to goto :-
1.admin login ->Site->Global Configuration > Server Tab > and select Yes to GZIP Page Compression
2.admin login->Site ->Global Configuration > Systems Tab > under the Cache Settings box, Select Yes to Cache.
3.admin login -> extensions ->template manager -> Your template -> Global – >
Css & Javascript Compress -> Optimize CSS set – ” Join & Minify & Compress”
Optimize JS->” Join & Minify & Compress” .
Apply and save .
For speedup of your Joomla website you can refer to this url:-
http://www.alrayeswebsolutions.com/blog/cms/how-to-speed-up-your-joomla-website/
waelali Friendwaelali
- February 2012
- 10 times in 1 posts
May 17, 2012 at 1:18 pm #453436<em>@pritam 246703 wrote:</em><blockquote>Hello idealist,
Apply and save .
http://www.alrayeswebsolutions.com/blog/cms/how-to-speed-up-your-joomla-website/</blockquote>
Thank you – That improved my webpage loading time by 3 seconds 🙂
However I need to improve it more , since I am testing it on internet bandwidth which is 20MB , and I do need to check it on 2.5 MB , which is I guess the max bandwidth in Arab World.How can we do that ??
tfosnom Friendtfosnom
- October 2010
- 200 times in 94 posts
May 17, 2012 at 5:44 pm #453483post the site url and we here in many countries with varying connection speeds will check load times for you. I am on a wireless connection that never gets speeds above 300 kps due to poor connection area
Cheers ShannonJune 1, 2012 at 10:42 am #455619Google with “.htaccess speed up site” and “smartoptimizer joomla” and you see more options to speed up your site.
altijd als eerste met het laatste lokale nieuws
- February 2012
June 1, 2012 at 1:16 pm #455627<em>@ditiswijk 323052 wrote:</em><blockquote>Google with “.htaccess speed up site” and “smartoptimizer joomla” and you see more options to speed up your site.</blockquote>
Smartoptimizer cannot be installed in Joomla 1.5 – why??
HeR0 FriendHeR0
- August 2011
- 588 times in 549 posts
June 5, 2012 at 7:09 am #456014Hi Waelali
Please get more information at http://farhadi.ir/projects/smartoptimizer/Regards,
mikel2004 Friendmikel2004
- January 2012
- 3 times in 1 posts
June 14, 2012 at 3:16 pm #457437I have the same problem. My site is http://comunidadzoom.com
I have a slow experience with less than 30 users and I need to have a big site for more than 1000 users.
I use joomla 2.5
So, what’s your best recommendation for config the server to obtain the best results with this template into the server?
You have tips or ideas to improve the template’s performance?Thanks a lot
HeR0 FriendHeR0
- August 2011
June 15, 2012 at 3:35 am #457481Hi Mikel2004
Best would be to check on google for resources on optimizing / speeding up your site.
When a website is slow, template’s performance is only one of the cases that need to be checked. Any site which loads lots of content from different sources is bound to be slow.
With JA T3 Framework, you can use optimize css, js, cache to increase loading speed.
This topic contains 10 replies, has 8 voices, and was last updated by HeR0 12 years, 6 months ago.
