  • gmmit Friend
    #171573
    Few problems with JA Ironis and JA Slideshow.
    First of all, bebas_neue font wont work at all in IE, huge issue.
    Cant save template changes via joomla admin panel, it stuck on load.
    Cant turn off t3 cache.
    With full cache on, optimized css/jc website is fuked up.
    Sometimes it takes ages to load JA_Slideshow (images are optimized), or it wont load at all together with mega_menu.
    Skype button wont load at all sometimes.
    P.S. Your ticket service is broken.
    TomC Moderator
    #428526
    Which version of IE are you using?
    Does the same thing occur in other browsers (i.e. Chrome, FireFox)?
    Have you tried clearing your cache – both browser and JAT3?
    gmmit Friend
    #428960
    I fixed font issue.
    Still have problems with cache and template changes saving.
    jooservices Friend
    #428993
    Sorry bit delayed your site working. I’ll be back at morning tomorrow to finish your site.
    Thank you for understand.
    jooservices Friend
    #429042
    Your server have a bit issue with permission.
    Almost owner is “apache” or “www-data”. I guess your template under another owner 😐 And that’s why you can’t save ( write permission ) and / or change caching issue.
    I tried logging w/ your root access gave me but you changed password. Please update. Or you can simply re-check your owner / permission in template folder.
    ( often case params.ini storing for template config )
    Thank you
    jooservices Friend
    #429277
    Everything fixed on your site.
    Thank you
This topic contains 6 replies, has 3 voices, and was last updated by  jooservices 12 years, 11 months ago.
