stellacadente Friend
stellacadente
- March 2012
- 2 times in 1 posts
September 2, 2013 at 10:20 am #190219Hi,
It happens in the job manager admin list.
As I access the job list, fields do not show data contents but ID nrs.
it’s been working properly until I have added a new text field!
Now instead of the name of employers and locations I get ther ID nr!!!If I leav the new field blank, it works properly.
In the list I contents of the fields does not show, the id nrs are shown instead the names of the locations and the emplyer we put.
As you can see in the followui and attached image.Would you pls tell me hew che I fix it in order to let the system show the contents: real names of locations and employers, instead of nrs?!
tx in advance for your help
PS: The FTP, directory is “lavoro”
HeR0 FriendHeR0
- August 2011
- 588 times in 549 posts
September 3, 2013 at 3:07 am #504300Dear Stellacadente,
You can remove both columns then try to add them back. It will work.
stellacadente Friendstellacadente
- March 2012
September 3, 2013 at 9:30 am #504367Hi,
tx a lot.i ve tried, but it does not work :((
HeR0 FriendHeR0
- August 2011
September 3, 2013 at 9:36 am #504370I have checked our demo site and it still works. Did you edit that field on Form Customizations and yoi might forget to rebuild DB function ?
AuthorPostsViewing 4 posts - 1 through 4 (of 4 total)This topic contains 4 replies, has 2 voices, and was last updated by HeR0 11 years, 3 months ago.
Location and employer fields do not resolve their contents in Job manager admin list
