  • jhouston Friend
    #203637
    Uber template – Business style
    This is basic information needed for every template you produce and should be in the documentation guide specific to each template.
    I have tried to follow other forums for other templates but no luck in finding where the ‘variable’ business is located that is displayed in the <title>business<title> in the head element. I have successfully loaded the favicon but can’t locate the variable to replace business with my site name.
    Please provide filename and its location to where this variable is being stored.
    To change to your site name you should edit your website name from Template Manager => Your default template => Theme Tab
    also check the name of your Home ( default page ) menu item , actually it is named Business
    1. Screenshot_9
    2. Screenshot_10
    jhouston Friend
    #558996
    Thanks that solved the problem. So simply, however it should be documented. In association with this what I find strange is that my favicon shows correctly when using FireFox browser but my ie 11 still displays the default Joomla in black icon. Both browsers have been refreshed and clear cache.
    This is your website on my IE11 as you can see favicon is correctly displayed
    1. Screenshot_12
This topic contains 4 replies, has 2 voices, and was last updated by  pavit 10 years ago.
