  • gianlucas Friend
    #202172
    i’d like to install a module ( third parties) ofjlan ajax login & register and I’d like to have a new position like “absoulte” where, for examlple, i can use the module on the top of my pages.
    Another way is to insert, in login menu, a style css link like “log-popup” but even in this case the solution does’nt work.
    Could you help me?
    Regards,
    .Gianluca
    wingly Friend
    #553364
    @gianlucas;
    IF you want it in a new position. then follow the link above and you will be bale to create the position where you want it
    http://t3-framework.org/documentation/layout-system.html#add-position
    About the other methed need to think more.
This topic contains 2 replies, has 2 voices, and was last updated by  wingly 10 years, 2 months ago.
