  • rgblogs Friend
    #195338
    Please look here:
    http://t3-framework.org/
    This theme is very similar to Purity III (Correct me if I am wrong)
    You can see Login and Register menu items on top right, with cool icons. I want to know how to configure these.
    Please help me someone 😀
    It’s our T3 Blank template: http://demo.t3-framework.org/joomla30/index.php/en/
    But in that T3 page, we customize the header of this template to add Login and Register module there (it will require JS code and additional style).
    rgblogs Friend
    #525464
    I do not want JS code for login box.
    I just need links for login and register page on my website.
    I think it is in module position: head-login
    So I guess I need to add some piece of code in header.php in tmpls/blocks folder.
    But I don’t know what to add :((:((:((
    That part belongs to header block, you can open the file: templatespurity_iiitplsblocksheader.php and add your custom code there.
    anitasheladiya Friend
    #532518
    I also want the same thing….
    Please please please help me if you had done this
    Thanks in advance
    Try to open header block of your site and include module you want into it: http://docs.joomla.org/JDocumentHTML/countModules and provide additional style for that module.
This topic contains 6 replies, has 3 voices, and was last updated by  Saguaros 10 years, 7 months ago.
