January 30, 2009 at 7:53 pm #137669
4185
Hello i have a problem with the login module. When i only put the login module in the ja-module it shows up alright, but when i want the search module right beside it does’nt work well. I cant figure it out how to make this work. I have read the user-guide but they only show how to put the login in the ja-login_module. I think i can fix this with css, but it doesn’t feel correctly.
Any ides?
Regards Peter
January 30, 2009 at 8:34 pm #289014Sometimes iam not to smart Uhh! :confused: The problem is solved. offcourse i cant put 2 modules at the sam position. The search_module should be in user4
AuthorPostsViewing 2 posts - 1 through 2 (of 2 total)This topic contains 2 replies, has 1 voice, and was last updated by sampras99 15 years, 10 months ago.
Login and search module problem with Ja-Pyrite
