  • eric67 Friend
    #138680
    I have just installed Avian II 1.5 version with quickstart. I can’t see the link to create a new account neither the link to retrieve a forgotten password. I precise that user registration is enabled (in the Global Configuration settings).
    Any idea ?
    Thank you,
    Eric.
    phild75 Friend
    #293963
    Hi – Check the default.php file in modules/mod_login/tmpl/. Perhaps the code that makes the Lost Password and Forgot Username functionality has been commented out or is missing?
    scotty Friend
    #293971
    This template uses ja_login. The register and password links are in a menu that appears above the login module.
    eric67 Friend
    #293978
    I installed the template with quickstart and the login module enabled is the usual one (mod_login). I can’t retreive ja_login anywhere in the type list.
    However, I found a solution a better solution. I installed the mod_yoo_login instead and it works very well!
    Eric.
    scotty Friend
    #293981
    Ahh OK. Sorry I should have pointed you to the override which is in your_template/ html/mod_login
    jgwalter Friend
    #294200
    <em>@scotty 115268 wrote:</em><blockquote>This template uses ja_login. The register and password links are in a menu that appears above the login module.</blockquote>
    The ‘Register’ link works, but the ‘Lost Password’ link does not. It sends the user to the registration page, even though this… “index.php?option=com_registration&task=lostPassword” …is in the link box of that menu item.
    eric67 Friend
    #294360
    I suggest to use the yoologin module instead. It works perfectly.
    Just type “yoologin” in Google if you want to download it.
    Eric.
This topic contains 7 replies, has 4 voices, and was last updated by  eric67 15 years, 9 months ago.
