  • mickman Friend
    #138746
    first, sry for my english. I hope you can understand my problem 🙂
    The Login isn´t possible with JA Labra and Components like joomgallery or jomsocial
    Example:
    Go to http://www.fotoseminare-paderborn.de/cms and login with
    Username: Maya
    Password mamama
    Then go to “Album” – “Neue Galerie” – all works fine. It´s the joomgallery.
    Please logout.
    Then go to “Album” – “Neue Galerie” and login. It isn´t possible.
    But with another Template like Purity the login ist working without problems.
    The same thing with the Component jomsocial.
    I´m using signallogin for the horizontal login. But with the normal login is it the same.
    Uff, i have to learn english 🙂
    I don´t know the cause of the problem. Perhaps you?
    Thanks in advance for help
    Michael
    Anonymous Moderator
    #294525
    Hi mickman,
    Could you send me your ftp account via PM so that i could have closer look on the issue?
This topic contains 2 replies, has 2 voices, and was last updated by Anonymous 15 years, 10 months ago.
