  • darrellnece Friend
    #120620
    http://www.csiroofing.com
    The logo commercial services a commercial reoofing company at the top left and bottom left are clickable broken links.
    How to i make it to where they are not links and just static logo?
    Also, how do i remove the http://www.yoursite.com from the bottom of the page?
    Thank you for the help,
    Darrell Nece
    Menalto Friend
    #221421
    In index.php at line 300 you find:
    <small>www.yoursite.com</small>
    There you can change to whatever you want.
    At line 147 you can change from:
    <div class="clearfix">
    <h1>
    <a href="index.php">
    <?php echo $mosConfig_sitename?>
    </a>
    </h1>
    To:
    <h1>
    <img src="<?php echo $ja_template_path;?>/images/logo.gif"/>
    </a>
    </h1>
    At line 310 you can change from this:
    <div id="logo-ext">
    <a href="index.php"><img src="<?php echo $ja_template_path;?>/images/logo-ext-<?php echo $ja_color;?>.gif" alt="<?php echo $mosConfig_sitename?>" /></a>
    </div>
    To:
    <div id="logo-ext">
    <img src="<?php echo $ja_template_path;?>/images/logo-ext-<?php echo $ja_color;?>.gif"/>
    </div>
    darrellnece Friend
    #221425
    Thank you very much for the help Menalto!
    Very fast response and solved every issue I had.
This topic contains 3 replies, has 2 voices, and was last updated by  darrellnece 17 years, 7 months ago.
