marinaw Friend
marinaw
- April 2007
February 6, 2009 at 2:07 am #137841We made a JA_Quartz quickstart installation (Joomla 1.5) and everything seemed to be fine, except that the logo was not visible in IE6. After experiencing countless problems to install a language package and a component (permission problems, I guess, but we were never able to make it work), we decided to make a fresh joomla install (Joomla 1.5.9), then applied the template, installed the modules and imported the database. This time everything was ok, we were able to install components, but the logo is still gone when we check the site using IE6.
It is OK in IE7, Firefox,Opera.
I searched the forums and found http://www.joomlart.com/forums/topic/header-image-not-showing-up-in-ie6/ , a similar problem with JA_Purity, but I was not able to make it work for us.
Any ideas?
Thank you in advance for your help,
marinaAnonymous ModeratorJA Developer
- 2008 times in 1700 posts
February 6, 2009 at 3:00 am #289805Hi marinaw,
I have looked your website on IE6, the logo is exist.
Did you fix this issue?Else please try to check your website with other computer? I think this problem only displays at your computer.
marinaw Friendmarinaw
- April 2007
February 6, 2009 at 3:10 am #289809No. Unfortunately I have not fixed it. I have IE 6.0.2800.1106 and it is not visible on that one.
thanks,marina
AuthorPostsViewing 3 posts - 1 through 3 (of 3 total)This topic contains 3 replies, has 2 voices, and was last updated by marinaw 15 years, 10 months ago.
Logo is not visible in IE6/permission problems when using quickstart
