cytropics Friend
cytropics
- April 2014
August 22, 2014 at 1:07 am #200717Hi there,
Need help to fix size of my header logo. I tried below:
http://www.joomlart.com/forums/topic/how-to-increase-the-size-of-the-box-logo-ja-j3-muzic/Also,
span2 to span4 for header and span10 to span8 for main menuSee results in attachment.
My logo is super small or don’t show. Help!
Thanks.
Nazario A FriendNazario A
- April 2013
- 284 times in 263 posts
August 22, 2014 at 2:25 am #546904You need to open file: /templates/ja_muzic/tpls/blocks/header.php then find and replace this code: (line 22 and 40)
<div class="span2">
<div class="span10">With:
<div class="span4">
<div class="span8">Also, you can refer at this tip. Let me know if this helps.
cytropics Friendcytropics
- April 2014
August 26, 2014 at 8:35 pm #547352Thanks for a response. When I change the span the 2 to 4 and span 10 to 8, the video playlist gets small everything shifts left.
Please see attachment.Read the tip to customize logo. <div class=”col-xs-12 <?php echo $logosize ?> logo col-sm-6″> does not exist in the ja-muzic template.
- April 2013
August 27, 2014 at 2:37 am #547369It would be best if you send me the URL, Admin, FTP credential of your site and let me know how do you want to change your logo so that I will help you out.
- April 2014
August 28, 2014 at 9:33 pm #547588Sent credentials.
- April 2013
August 29, 2014 at 2:23 am #547602I just checked your site. You are using JA Biz template, not JA Muzic template. If you want to make your logo to larger, you can do it by two ways:
#1: Replace the small logo with the larger logo.
#2: Open file: /templates/ja_biz/css/custom.css (if not exists, pls create new one), then add this rule:
.logo-image .logo-img {
height: 80px;
max-height: 80px;
}You can change the value as your wish.
- April 2014
August 31, 2014 at 5:28 am #547743Thanks. I changed the template. Your solution works flawlessly with new template, could not get it to work with previous template.
AuthorPostsViewing 7 posts - 1 through 7 (of 7 total)This topic contains 7 replies, has 2 voices, and was last updated by cytropics 10 years, 3 months ago.
