  • usertini Friend
    #1091123
    The problem of the slideshow, slidecontent and megamenu I have solved thanks to this post I have disabled in the management of the template the optimization of the javascripts. It is clear that when dealing with an update with an important jump between versions, some javascript creates the conflict.
    But the problem of losing blog style with K2 still persists
    • This reply was modified 6 years, 10 months ago by  usertini.
    Kindly share the credentials of your site so I can take a look.
    usertini Friend
    #1091284
    Thanks, but it is not necessary anymore, the problems are solved.
    I will close the post
    usertini Friend
    #1091285
    The problem with the style of the blog of K2 was a simple change in the configuration of the template to be used by K2, instead of Mendozite should use Medozite blog.
    Can you close the post ?. The problem has been solved but I do not have permission to close the issue.
This topic contains 4 replies, has 2 voices, and was last updated by  usertini 6 years, 10 months ago.
The topic ‘Lost module positions (slideshow and slide content), megamenu not work and more’ is closed to new replies.
