  • saryon Friend
    #123898
    Hi all,
    I really love the layout and colors used in this theme. I was able to get it installed on 1.5 with few problems, but I can’t seem to get my articles to display one on top of the other. All articles except for the first one are aligned 2×2. Is there a setting I am missing to have these arranged in a single column within the body section?
    Other than that, everything else is working fine so far. LOVE the user5 option. It saves so much needed space.
    Thanks a ton.
    Tom
    kashxo Friend
    #233133
    For this issue, please login into your Administrator area, then choose Menus >> Main Menu
    Then click on Home.
    On your right hand, at Parameters – Basic, you will see the box name Columns, change it to 1 is what you need.
    Cheers 🙂
    saryon Friend
    #233186
    That’s perfect! Thank you so much for the tip. I’m still getting used to the new 1.5 layout and such, but slowly I learn where all the new options are.
    Thanks again!
    saryon Friend
    #233187
    One more question. The image used to seperate articles is missing. I’m not getting an “X” stating that the image file itself is missing, though. Is there an option somewhere in the settings that enables/disables this? Or is it just not available in the v1.5 version of Fagus?
    saryon Friend
    #233254
    Scratch that. I found the issue. The class “.article_seperator” is misspelled in the css. html spelling is _separator, css spelling is seperator.
    Cheers
This topic contains 5 replies, has 2 voices, and was last updated by  saryon 17 years, 1 month ago.
