  • greatjava Friend
    #156870
    It appears the latest version of Kunena forum software uses Joomla menus for it’s menu system. So I’d like my “forum” link to stay highlighted when in the menu items of the Kunena menu. I have created a menu alias link that works in a few other test themes but it doesn’t work with any of the menu options in JA-Social. The main menu isn’t highlighted when the forum menu items are selected.
    You can see in action at http://galaxytablettalk.com
    Thanks for any pointers on how to get this to work.
    Hello
    Now, please try testing this again: you disable SEF: and then check the forum link: have it got the hightlight acitve?, if have, so the probelm is from the alias conflicted, you need to change current by other alias.
    If the problem is not fixed, provide me the link administrator account, i would like to check the issue in detail
    greatjava Friend
    #364777
    I disabled all SEF. I tried the forum link again and no change, non-SEF url’s don’t hepl fix the problem.
    I’ll send you the login, thanks.
    ok, now please provide me the account information via your ticket
    greatjava Friend
    #364933
    The ticket created for me I cannot access, my member login doesn’t work for the ticket system. I created a new ticket #ZQH-710-11150 but still don’t know how to login to your ticket system.
    Don Lee Friend
    #364951
    <em>@greatjava 206180 wrote:</em><blockquote>The ticket created for me I cannot access, my member login doesn’t work for the ticket system. I created a new ticket #ZQH-710-11150 but still don’t know how to login to your ticket system.</blockquote>
    In order to login our helpdesk, please use account with username is your email address and password is the one combined with this forum username.
    greatjava Friend
    #365043
    Don,
    I did try my email on my account with my current forum password – no dice.
    Don Lee Friend
    #365046
    <em>@greatjava 206320 wrote:</em><blockquote>Don,
    I did try my email on my account with my current forum password – no dice.</blockquote>
    I just tried to login with your email mark@glyshaw.com successfully. Please try again!
    greatjava Friend
    #365174
    interesting… I didn’t know my account was using an old email, should have tried that. Thanks!
    The first ticket opened was already automagically closed. The new ticket has my server information on it (#ZQH-710-11150) if you want to take a look and see what might be going on.
    Hayden A Friend
    #365787
    we are fixing the bug, will come back to you after that.
    cssyeah Moderator
    #366069
    This issue is fixed and will be updated in new version of T3v2 Framework soon.
    @greatjava: the fix is sent through ticket.
    davidyv Friend
    #366087
    <em>@trungch 207673 wrote:</em><blockquote>This issue is fixed and will be updated in new version of T3v2 Framework soon.
    @greatjava: the fix is sent through ticket.</blockquote>
    Hi trungch,
    How to fix this issue? I using the latest jatc_t3_blank_j15, Kunena 1.6.1 and to change the code at ../administrator/components/com_kunena/elements/kunenacategories.php:
    30 line:
    [PHP]$options [] = JHTML::_ ( ‘select.option’, ‘0’, $none ? JText::_ ( $none ) : ‘ ‘ );[/PHP]
    to:
    [PHP]$options [] = JHTML::_ ( ‘select.option’, ”, $none ? JText::_ ( $none ) : ‘ ‘ );[/PHP]
    But it can not work.
    hmm, your issue is related to the issue mentioned in the thread, Can you please provide more information on this?, if possible, provide same snapshots on this?
This topic contains 13 replies, has 6 voices, and was last updated by  Saguaros 14 years ago.
