test melih
 melih
  • ejbjane Friend
    #187720
    Has there been a fix for the problem that you can only have one mainmenu in T3, I would have expected this by now.
    So to recap : mainmenu does not appear if you create mainmenus for several languages
    Is there a workaround, patch or clear tutorial to explain how to tackle this problem?
    I understand that we could use one of the following workarounds in (I imagine) in argo_plugins/system/t3/includes/core/templatelayout.php
    However can someone please tell me where I need to insert this and which is better to use please.
    $lang = JRequest::getVar(“lang”);
    $japarams->set(‘menutype’, $this->getParam(‘menutype’, ‘mainmenu’.$lang));
    or
    $lang = JRequest::getVar(‘lang’);
    $japarams->set(‘menutype’, ‘mainmenu’.$lang);
    As I’m not a PHP programmer and I’m working on a localsite so I cannot give any live example. Sorry about that.
    Hi ejbjane,
    This is a bug from T3 which doesn’t display mega menu for multilanguage in backend. You can follow and join discussion here: https://github.com/t3framework/t3/issues/83
This topic contains 2 replies, has 2 voices, and was last updated by  Saguaros 11 years, 8 months ago.
