Viewing 5 posts - 16 through 20 (of 20 total)
  • sharpdome Friend
    #393016
    As traffic ramps up on the site this problem is happening more and more frequently, sometimes within minutes of clearing the cache. If I disable all caching within JA Social and put the template into Development Mode it still loses those two css files. Joomla cache and Job Board cache are enabled.
    Any ideas how to fix it? It’s 100% reproducible on my site. 🙂
    sharpdome Friend
    #393035
    OK, when I disable Job Board cache and enable both template cache and Joomla cache the css error does not occur. It looks like a problem with the Job Board cache process. I’ll submit a ticket to the Job Board team.
    sharpdome Friend
    #395782
    I was wrong. Even with JB Cache disabled the CSS gets broken.
    The problem is intermittent. Can someone please help?
    sharpdome Friend
    #396376
    Problem fixed by moving the JA T3 Framework plugin to the end of the system plugins.
    I didn’t fully realize it had a cache function, and that all Joomla cache plugins must be the last ones called.
    It was the post here that finally tipped me off: http://www.nonumber.nl/news/blog/463-plugin-order-is-important
    Phill Moderator
    #396483
    Many thanks for sharing your findings. I am sure many other will find that usefull.
This topic contains 20 replies, has 3 voices, and was last updated by  Phill 13 years, 5 months ago.
