  • bramewave Friend
    #135212
    I’ve had these problems with this site before, I have since had to redo this site:
    http://www.bramewave.com/portfolio
    Below are my problems:
    1. I need the area for my header images to be wider so that the image fits the image size is 950×300. I would also like for the images to rotate. They are not doing that at this point.
    2. I am trying to add separator buttons to the main menu until I am ready to complete and this does not work, when I add one all the buttons disappear.
    3 I would also like to add a module position to the body so that I may insert a slideshow there like in my other site(http://bramewavestudios.com/index.ph…d=17&Itemid=47)
    Any help would be appreciated,
    Mike
    #280467
    Hi brameware !
    1.About the first problem :
    I have checked your site and see you solved it .
    2. About the second problem :
    You can fix it following way below :
    Open Base.class.php file in templatesja_kulaniteja_menus folder , find following code section at about line 70 :
    case 'separator' :
    return '<span class="separator">'.$v->name.'</span>';
    break;
    and remove it.
This topic contains 2 replies, has 2 voices, and was last updated by  Sherlock 16 years, 1 month ago.
