Viewing 15 posts - 1 through 15 (of 18 total)
  • timeoutcorner Friend
    #205370
    I am trying to figure out if there is a way to get all components to have the same look as the categories when mousing over the menu scroll. As when I try to use the menu scroll over a component the scroll menus are hard to see as the transparency is not working the same way as with the categories.
    I have attached photos of the component with mouse over menu scroll and regular categories.
    1. component-menuscroll
    2. menuscroll
    Could you send me URL of page where has that component?
    #566363
    Yes no problem.
    I couldn’t access that link, pls recheck: http://prntscr.com/6stx52
    #566683
    You should be good to access it now I had it closed.
    You can try with my tweak here:
    – Go to css file: /templates/ja_smashboard/css/custom.css (create this file if it doesn’t exist)
    – Add this css rule:
    .t3-mainnav.focus+.t3-mainbody > div {
    opacity: 0.25;
    filter: alpha(opacity=25);
    z-index: 1;
    #567110
    I tried that and changed the opacity a few times but did not come up with any changes after applying them.
    You can PM me ftp account of your site, I will take a look.
    #567296
    Okay no problem
    Kindly check my private message 🙂
    #569820
    I think I found an issue as to why the css rule you provided above did not work. It seems for some reason that my custom.css file is no longer accepting any new css rules. All old custom rules are working fine but any new ones I try to put in there do not take affect at all. I am not sure why.
    #734902
    Kindly check the permission / file ownership for this file and make sure that this file is writable. Then try to update the css rule again.
    #569952
    Yes it is writable the file takes the changes but for some reason none of the new changes take affect.
This topic contains 18 replies, has 2 voices, and was last updated by  Saguaros 9 years, 7 months ago.
