  • melvine Friend
    #662757
    Did JA Teline V and SH404sef are compatible ?
    I have many problems when I activate SH404sef.
    All the modules take the wrong place in the categories
    Please see the picture below
    http://img15.hostingpics.net/pics/214998problemsh404sef.png
    Instead of the correct position
    http://img15.hostingpics.net/pics/236810problemsh404sef1.png
    Thank you for your help
    Best Regards
    Ninja Lead Moderator
    #662856
    It’s pretty hard to suggest the solution for you but without clue, you can pm me URL of your site, admin login backend site and FTP account, I will help you to check this bug directly on your site.
    jooservices Friend
    #662861
    Hi there
    Just for adding information. I have faced similar issue before.
    It’s all about itemid. Sometime by some reason sh404sef or Joomla! SEF caused lost itemid . And of course without it. Module / template assignment will mess up 🙂
    Please try to print itemid for checking.
    Thank you,
    Viet Vu
    melvine Friend
    #663842
    Thank you guys,
    Thank you very much Viet Vu for your answer, I will look in that way
    It’s not easy to configure sh404sef with Teline V
    Best Regards
    melvine Friend
    #746179
    Thank you guys,
    Best Regards
    jooservices Friend
    #665108
    Hi there
    Have you managed your issue ?
    In fact i would not suggest use 3rd SEF extension except we exactly know how does it work to handle it .
    I have used sh404sef for few years. But now i leave it.
    Thank you,
    Viet Vu
    jooservices Friend
    #746499
    Hi there
    Thank you,
    Viet Vu
    melvine Friend
    #693412
    Hi Viet Vu ,
    Yes you show me the good way with itemid, I think it will be okay.
    For now I made only some tests. I will tell you when I will install definitely the component ( because I need sh404sef )
    Best Regards;)
    Melvine
    melvine Friend
    #749956
    Hi Viet Vu ,
    Best Regards;)
    Melvine
This topic contains 9 replies, has 3 voices, and was last updated by  melvine 9 years, 2 months ago.
