  • Luna Garden Moderator
    #898193
    Hi Alameiras,
    In order to make search filter has map like demo, you must use template K2 Directory. But in your folder K2 of JA Directory (templates/ja_directory/html/com_k2) you have copied the wrong structure for ‘ja_k2filter’ folder, just copy only folder ja_k2filter to com_k2, not whole folder ‘templates/ja_k2filter’.
    The right structure should be:
    com_k2
    | default
    directory
    | __ ja_k2filter
    Then go to K2 category, set template to Directory. And go to JA K2 Filter >> Option >> tab Search Result Item Layout >> Select template to Directory.
    You can send me your FTP account, then I can help you set up this.
    alameiras Friend
    #899361
    Hi!!problem fixed..
    i had wrong structure and selected templates..
    Thanks 🙂
This topic contains 2 replies, has 2 voices, and was last updated by  alameiras 8 years, 8 months ago.
The topic ‘Map filter problem’ is closed to new replies.
