March 14, 2014 at 11:29 am #195777
Hi :I just installed JA Masshead module (from JA Extensions Club) with Purity III .I have tried with Blog layout among others and Masshead position is not among the available positions, unsurprisingly the Masshead module is not showing.
Help will be appreciated:)chavan Friendchavan
- October 2014
- 1440 times in 1290 posts
March 14, 2014 at 12:17 pm #526733can you just read this post, it is answered here http://www.joomlart.com/forums/topic/interesting-masthead-functionality-can-it-be-used-for/…
March 14, 2014 at 2:11 pm #526749Hi Chavan: Thanks so much for your speedy reply. However, perhaps i did not explained myself clearly enough or perhaps I did not understand your explanation: the module configuration assumes that I have assigned it to the “masshead” position (as explained in the one-before-the last note (“Is the module assigned to a visible module position ?”) in the userguide http://www.joomlart.com/documentation/joomla-module/ja-masshead .In the layout I chose in Purity III (“Blog”) there is no such a position to be chosen . The only available position starting with “mas” is “mast-col” and even “masthead” is not available ( it appears as default in the layout but I assume this is not the same as “masshead” and in any case the module does’nt work)
PS Actually I am wondering: is there such a position “masshead”?chavan Friendchavan
- October 2014
March 15, 2014 at 5:31 am #526794yes there is a position called “masthead” in purity iii, so you can make use of that
March 17, 2014 at 6:34 pm #527020Hi Chavan.Thanks again. I set the position to “masthead” and it did work – partially.The text I set for Title and Description are showing , but not the background picture. I am using the following code for Configuration conditions:
[Masshead option=”com_content” view=”article” title=”<h1> My Title </h1>” id=”18″ background=”images/mm.jpg”]<h3>My Description</h3> [/Masshead]
But picture mm.jpg is not showing as background.I read in the user guide that “background” should be defined as a new param? Where/in which file?
And another question: can the height of the masthead be changed ? how?
The purpose of the JA Masshead module is not clear to me since I can achieve a similar result using the Page Display Options functionality in the menu item
October 8, 2014 at 2:07 pm #552279Hi norman_mm,
I have exactly the same problem than you. The JA masshead module don’t display images in background (Template : Purity III, blog layout, position masthead)
Did you fix it ? Or anyone know how to do ?
thanks
chavan Friendchavan
- October 2014
October 8, 2014 at 4:09 pm #552305please post the exact site Url and admin details in PM.
October 9, 2014 at 7:59 am #552373Hi kevan76:
Unfortunately I did’nt get too far and the problem is still unsolved.You may find interesting posts at the JA Masshead Module forum :
http://www.joomlart.com/forums/forum/ja-masshead-module/I will follow up your post .
chavan Friendchavan
- October 2014
October 9, 2014 at 1:59 pm #552403Try this code for blog layout
This is the Syntax
[Masshead option="com_name" view="view_name" layout="layout_name" task="task_name" id="id" title="Title" ]Description here[/Masshead]This is the example
[Masshead option="com_content" view="category" layout="blog" id="88" title="your title here" background="masthead-bg.jpg"][/Masshead]
October 11, 2014 at 7:31 pm #552604Hi Chavan:
Is not working yet. Let me give you some additional info:
in the ja-masshead module I set Configuration Conditions to :
[Masshead option=com_content view=article id=3 title=”My Title from Configuration Conditions!!” background=”banner_cradle.jpg”] My Description [/Masshead]
(I saved under my_site/images: banner_cradle.jpg and I tried the above code with: /images/banner_cradle.jpg or images/banner_cradle.jpg, with no success).
I tried also adding a file default.php file under: templatespurity_iiihtmlmod-jamasshead ( I created folder mod-jamasshead which did not exist) with code:?php
defined(‘_JEXEC’) or die(‘Restricted access’);
<div class=”ja-masshead” <?php if(isset($masshead[‘params’][‘background’])): ?> style=”background-image: url(<?php echo $masshead[‘params’][‘background’] ?>)” <?php endif; ?>>
</div>Did not work either.
I would appreciate your help.
Thanks,chavan Friendchavan
- October 2014
October 12, 2014 at 1:50 am #552605can you please post me the site Url and admin details via PM and post me the exact Url where you want to show the Masshead.
October 13, 2014 at 2:23 pm #552768<em>@Chavan 449629 wrote:</em><blockquote>can you please post me the site Url and admin details via PM and post me the exact Url where you want to show the Masshead.</blockquote>
Hi Chavan: I am developping in my local computer so the only thing I can think about is upolading temporarily my site somewhere which would allow this sorty of thing. At any rate it is a very small site ( and actually in Hebrew) where I am trying to use the extension so as to apply it later in a larger scenario. Is there some specific code and/or configurations from my site that I can supply that may help you identify the problem?
Thankschavan Friendchavan
- October 2014
October 13, 2014 at 3:26 pm #552773Please post the code into the development server. since Without checking it, It is going to be a tough call to provide a solution. Please help me on this to help you.
October 14, 2014 at 7:38 am #552854Sure, but I am not familiar with the “development server” . Where and how should I upload the code? Or just paste it here in the blog?
This topic contains 18 replies, has 5 voices, and was last updated by norman_mm 8 years, 11 months ago.
